Idler Arm Repair Kit - Highly Recommend
Subscribe
Aug 1, 2009 | 08:59 PM
Get the Idler Arm Repair Kit, especially if you have replaced both the Steering Damper and Linkage Assy.
Months ago I replaced the Steering Damper and Linkage Assy but when I got the Idler Arm Repair Kit installed a week ago the steering is so tight at high speeds.
Before, the issue I was having was the faster I go the more play there was in steering and the less road feedback I could feel. This was always around 95-100mph and it felt like I had no control or was loosing control.
Reply 0
Aug 2, 2009 | 02:28 PM
Quote: Get the Idler Arm Repair Kit, especially if you have replaced both the Steering Damper and Linkage Assy.
How much did the repair cost?
I have the kit(bushing and bolt) but have enough room to work. I had everything but the idler bushing replaced.
Reply 0
Aug 4, 2009 | 08:24 AM
My shop did it for free But out of any thing else I would recommend everyone get theirs replaced ASAP.
Steering is so tight now, it's like someone tied my new shoe laces tight.
Reply 0
Aug 4, 2009 | 11:36 AM
Quote: My shop did it for free But out of any thing else I would recommend everyone get theirs replaced ASAP.
Why did you replace the linkage assy?
Reply 0
Aug 4, 2009 | 01:35 PM
I wonder how tricky this is for DIY? I did lower ball joints, tie rod assembly and lower control arm bushings so far. My front end is very tight but it still wanders a little bit.
Reply 0
Aug 4, 2009 | 06:12 PM
Quote: Why did you replace the linkage assy?
I was driving and when I got up to around 50mph my car started shaking really bad. I had new tires and a new alignment. It was shaking so bad I though my tires was about to shoot out from off the fender. Luckily my dealership was only 5 mins in the other direction. They said that is a common part to go bad and he also recommended to replace the steering damper. I just wished he also recommended at that time to do the Idler Arm Repair Kit.
Reply 0
Aug 4, 2009 | 06:56 PM
Quote: I was driving and when I got up to around 50mph my car started shaking really bad. I had new tires and a new alignment. It was shaking so bad I though my tires was about to shoot out from off the fender. Luckily my dealership was only 5 mins in the other direction. They said that is a common part to go bad and he also recommended to replace the steering damper. I just wished he also recommended at that time to do the Idler Arm Repair Kit.
I may look into having that done...
Reply 0
Aug 5, 2009 | 01:29 PM
Wait... What's the linkage assy consist of?
Reply 0
Explore
Aug 5, 2009 | 07:45 PM
Quote: Wait... What's the linkage assy consist of?
Reply 0
Aug 5, 2009 | 09:55 PM
Drag link..center link, inner tie rods, and outer tie rods.
How long did it take for them to replace the idler bushing. I need to get this done as I've replaced everything else replaceable in front.
Reply 0
Aug 6, 2009 | 12:27 PM
Williams, thanks for the picture!!
Reply 0
Subscribe
Currently Active Users (1)
