Oh no!
Old Feb 21, 2003 | 06:46 PM
russdog's Avatar
2014 ML350 BlueTec
Oh no!
Just cleaning the inside of my car and noticed a crack in the dash board. As many of you may have noticed I just bought my car on Tuesday. It's a used car, however it is still under 4 year 50k warranty. Please... someone tell me this would be covered under the warranty.
Old Feb 21, 2003 | 06:59 PM
Mach430's Avatar
Yes, it's a warranty issue, you shouldn't have any problem getting it replaced.
It does look like the crack is around the border for the passenger side airbag. If this is the case, it could be possible that the car was in an accident, in which it deployed and made the crack.
Old Feb 21, 2003 | 07:05 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Ben has some validity, however, I see some fibers still attached as if the airbag didn't tear through it, so, its probably just a bad case of that cracking.
Many pre-'00 CLKs have that issue. Its a warranty fix, replace the entire dash.
Old Feb 21, 2003 | 07:06 PM
russdog's Avatar
2014 ML350 BlueTec
Thanks!
That is exactly the spot. I thought of the accident thing myself, but wouldn't the crack be all th way around the air bag? It's only on one side(left).
Russ
Old Feb 21, 2003 | 07:09 PM
CLK 320's Avatar
2001 CLK 320
Airbag
Russ, this was an issue that we were discussing awhile back. The area around the passenger's side airbag is vulnerable to cracking, so please don't be too concerned about an accident. As far as I know it is a warranty fix, but I'd make a list of everything you need and make an appointment ASAP.
Old Feb 23, 2003 | 12:20 AM
3 bAn 2 PoW 0's Avatar
CLk320
OMG! 2day i was cleaning my car and i have the same problem! i'm going to bring it to the dealer as soon as possible. is there anyother problems i should check on my 99 CLK320. thanks
-Greg
Old Feb 23, 2003 | 12:40 AM
JohnAMG's Avatar
3 Porsche rotation
This happened to my wife's 98 CLK320 around 44000 miles and it was repaired under warranty. It is a common problem with CLK and E-class(W210). Get it done soon before warranty expire, it would cost more than $700.00. Other than this, the 98 CLK320 has been a reliable car.
John
