De-badging the CLK
What about the rear star? Is it glue on or is there a little hole on the hood to hold it in place?
Thank in advance for your valuable advice.
I'm pretty sure the star is glued on (no hole) as well. My friend's was stolen, but it broke in the middle and the thief only got part of it....
The best way I've heard to get the badges off is to heat them with a heat gun or blowdryer, then just pry 'em off. I don't know what to recommend to get the sticky junk off, but some paint-safe cleaner/solvent should work.
BTW- I don't live in the ghetto, people are just a$$holes.
The star is held on in the middle w three pegs. Open the trunk, remove the carpet from the trunklid by pulling the little black pegs out, then press the pins (of the star) from the back side outward. Once you have it out a little you can pull it the rest of the way out from outside.
You will want to get a good bodyshop to fill the holes.
