Which wire is the ACC wire?
Old Sep 17, 2009 | 03:55 AM
GiZzO's Avatar
CLK55 / E350 Coupe
Correct me if im wrong here:
Brown = Ground
Red = 12v battery
Blue = ACC?
Yellow = ?
Green = ?
This is for the becker POS non nav with the tape deck. Trying to replace it badly
Old Sep 17, 2009 | 09:08 PM
GiZzO's Avatar
CLK55 / E350 Coupe
post by bnz. https://mbworld.org/forums/2053395-post47.html
1. BROWN (big wire): Chassis Ground
2. RED with VIOLET strip (big wire): 12 Volt Ignition/Acc
3. BLUE with WHITE strip: Amp Turn-On (Remote)
INPUTS (from Headunit to Amplifier) - 8 THIN wires:
4. GREEN: + Left Front (input)
5. BROWN with GREEN strip: - Left Front (input)
6. ORANGE: + Right Front (input)
7. BROWN with ORANGE strip: - Right Front (input)
8. PINK: + Left Rear (input)
9. BROWN with PINK strip: - Left Rear (input)
10. WHITE: + Right Rear (input)
11. BROWN with WHITE strip: - Right Rear (input)
OUTPUTS (from Amplifier to Speakers) - 10 THICK wires:
12. GREEN: + Left Speaker and Tweeter in the Front side of the door (output)
13. BROWN with GREEN strip: - Left Speaker and Tweeter in the Front side of the door (output)
14. ORANGE: + Right Speaker and Tweeter in the Front side of the door (output)
15. BROWN with ORANGE strip: - Right Speaker and Tweeter in the Front side of the door (output)
16. PINK: + Left Speaker in the Back side of the door (output)
17. BROWN with PINK strip: - Left Speaker in the Back side of the door (output)
18. WHITE: + Right Speaker in the Back side of the door (output)
19. BROWN with WHITE strip: - Right Speaker in the Back side of the door (output)
20. GRAY: + Left Speaker(subwoofer) in the rear deck (output)
21. BROWN with GRAY strip: - Left Speaker(subwoofer) in the rear deck (output)
22. VIOLET: + Right Speaker(subwoofer) in the rear deck (output)
23. BROWN with VIOLET strip: - Right Speaker(subwoofer) in the rear deck (output)
So there is the ACC wire, now where is the battery connection? tap into the cig lighter for battery?
Old Sep 22, 2009 | 03:42 AM
GiZzO's Avatar
CLK55 / E350 Coupe
Woot, love it! glad i waited for the X series to come out. I'll take better pics when its done.
Just need a good looking faceplate, which im afraid does not exist.
For reference: (vw metra harness is not plug and play some wire shifting was needed for my becker/bose stereo)
CIG LIGHTER: Battery connection
BLUE with WHITE strip: plug to remote turn on headunit need it for bose amp to turn on
Parking brake bypass:
Ground parking brake with ground
move mute wire to pin 8 and ground
Speakers match up perfectly with metra harness
