Is sway bar that important ?
Eibach seems to no longer be making them (last I checked). Most other companies uses the CLK55 diameter (or actual) bar. Of course, getting the bar isn't the simple either. As of last week, there were none in the country, and had to be ordered from Germany...
If there is enough demand, I can make adjustable sway bars for the CLK, but it would take about 20 people or so.
Can you tell me more about the Renntech one ?
Mach430 what is the price of the adjustable sway bar ?
You'd have to check with eibach (who makes the AMG bars), but I don't think they have any more for the w208. I think the AMG bars are around $550. I would not spend more for the bars, unless something is uniquely different about them (i.e. diameter, stiffness, etc).
............You may be right. But I looked into this question before I decided to go ahead and order my sway bars. The information I received was that these sway bars are difficult to find, especially after Eibach stopped making them for most MB lines. As a result, I was unable to locate even one person that has an aftermarket sway bar on their MB. Therefore knowing how much of a difference the sway bars make is known becayuse no one on this forum so far, as far as I know has done it. I decided to get the Renntech sway bars(which admittedly is expensive but they are the only company that I know right now that makes them for MB's) and see for myself. I will post results. If anyone has had an aftermarket sway bar omn their CLK, kindly post your impressions so we can be better educated.
Ted
Unless you are racing on the track, I think it's a waist of money for normal daily driving. Springs, shocks and tires are more than enough.
Ted
theine: if i just change the spring without the shocks, is it bad?
