Manual Shift Control?
Does that mean I can actually shift gears in my car with the gear shifter?
I always leave it in drive.
I thought that is bad for your car because there is no clutch
Can you actually switch gears?
I think you are only supposed to manually shift the cars with the triptronic model years 2000 and up. The 99 and below have the gears showing on the console but I heard that it was bad to continually use them like a manual transmission, this was the reason Triptronic was added later.
I could be wrong so hopefully someone else chimes in and helps me out here.
Greg
Greg
In the city I use 4th gear to keep the transmission from changing into overdrive so much. I use D drive on the freeway.
Iv'e changed gears in my CLK a couple of times but it wasn't any fun.
