Front camber problems. HELP!!!
Old Nov 5, 2009 | 02:31 PM
murdock's Avatar
clk 320
I'm sick and tired of replacing my front tires every 3 months or so. I have 235-35-19's in the front with KMAC LCA bushings and I've taken the car to several alignment shops, but nobody can seem to get the correct camber setting.
Is this just what its like when you have 19's? I'm thinking of going back to 18's...
Does anyone know of a good alignment shop in Orange County CA?
Thanks in advance.
Old Nov 6, 2009 | 12:02 AM
tery's Avatar
CLK320
what is your setting right now ?
I am at -2 on the front with 0 toe. wear is even maybe you want to try toe in at 0.
Old Nov 6, 2009 | 11:44 AM
murdock's Avatar
clk 320
I don't have the specs in front of me, but front camber was around -2 to -2.3 range if I remember correctly. Not sure about the toe. What springs and pads are you running?
Old Nov 6, 2009 | 09:08 PM
tery's Avatar
CLK320
I am on KW suspension with thinnest pad from Mercedes.
Old Nov 20, 2009 | 05:25 PM
click430's Avatar
12 CLS 550, 65 Shelby 427 SC, 03 GMC Envoy
Have you checked your wheel bearings?? I just had mine replaced, and my alignment will actually last past the first pothole... I was wearing the insides, feathering and cupping... not now...
Old Nov 20, 2009 | 07:04 PM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
if you're lowered, u need to buy some camber arms (def works for rear, i have em. dunno about front). you can add factory camber bolts in the front.
Old Nov 21, 2009 | 12:38 AM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
bro i had the same pro and i have 235 35 19 and mine is slammed..Kmac front will help even though
i stated earlier that the front camber kit did not work,BUT it did... The stupid ***** who did the alignment did my front wrong and broke my bushing since he never loosen the bolt b4 he turned the wheels.
i was sitting at -3.2 and now im at -1.7 which is very close to spec.
its not perfect or within the spec, but def its must better than b4.
i was wearing tires every 2 months a half, mAX 3 months if i was lucky
