HELP--Mercedes is in the process of screwing me over
1-6/13/08 61,966mi Customer states trans slips and has delayed angagement. Repair- serviced trans, changed fluid and filter, found fluid contaminated (didnt say what with)
2-7/5/08 63,094mi Owner states coolant leak. Repair-fan shroud hitting upper radiator hose, oil in radiator due to internal cooler leak, replace radiator and service trans due to glycol contamination
3-9/3/08 64,726mi Owner states oil in coolant reservoir and trans "bangs" real hard when shifting. Repair-oil in coolant tank from previous leak also flushed trans fluid and checked system.
4-12/2/08 67,224mi Customer states "check on previous trans repair. (One could ONLY presume that if everything was OK with the trans they wouldnt have askd them to check it)
5-10/5/09 79,957 Customer states trans stumbles on 2-3 shift Repair-adaptations for K2 clutch at limits quote replacement trans
6-10/09/09 Customer states check trans Repair--Removed transmission pan found severe glycol contamination, R/R trans, rebuild, found lip seals damaged from glycol contamination, replace radiator.
Owner #1 bought the radiator (cust pay) I am owner #3. My trans repair was "just outside" of their 12/12 parts warranty. I contacted the dealer that installed the rad originally. After some time they told me that their region MB rep told them there would be NO assistance from MB on this issue. The dealer service manager stated that his rep didnt even give him a case # on this matter.
There is NO WAY anyone can convince me that the rad was not leaking glycol prior to the expiration of the 12/12 waranty. Is this how MB treats their customers?? Is this how MB stands behind their product?? I spent the last 30 years a loyal GM customer and this is my first anything else. MB advertises "superior engineering"---I have my doubts. Any assistance here in dealing with MB would be appreciated.
Your transmission was on it’s way out in June of 2008. The very first time the clutches saw ethylene glycol (antifreeze) they started coming apart. Right now, the radiator they just took out of your car may still be good. Why do I say that? Dealers replace subsystems. They saw coolant in the transmission and followed the manual. The service manual says replace radiator AND rebuild transmission.
I think the beef is with the owner who intentionally dumped a car with a bad transmission. I don’t think you’re going to see a dime from MBUSA – UNLESS you had a PPI done at a dealer. If you had a dealer perform an inspection, and they missed the dead trans MAYBE MBUSA will help you out. Then again, they may tell you to take that up with the dealer who did the inspection.
Did you buy the car from the dealer who originally replaced the radiator? If so, the arguement can be made that they knowingly sold you a car with a bad transmission.
Sorry to be the bearer of bad news.
But there still remains the fact that the dealer replaced the radiator assembly and it failed. Understandably this would be a parts warranty issue. Also to what would the trans failure be credited to. You credit it to the first rad faiure, couldnt it be the second rad failure? There is nothing other than minor shifting issues reported until the second radiator failure.
edit---i reread your post
1--thank you for responding
2-I believe you misread the repair history. It is
(1)simple trans service---(2)glycol in trans / rad replace----(3)service trans again(possible convertor issue you note)----(4)severe glycol in trans, overhaul trans and replace radiator the second time.
I believe I understand your post. It appears someone had the fluid changed 3 times in the summer of 2008. To me, that’s sounds like something was wrong with the transmission in 2008. Whoever owned that car in 2008 knew the transmission was bad.
BTW, what does a dealer charge for a rebuilt transmission?
