FS: Brabus shock and spring for 320
Hi everybody
when I was cleaning out my storage I found that I still have a set ( front and rear ) Spring and shocks from Brabus
I have it on for about less than 7000KM I am looking for $400CND obo
Let me know teryps2@hotmail.com
Thank you.
Thank you.
this if from MarcusF
There is no universal 'stock pad'. Mercedes-Benz makes pads in these sizes: 5, 9, 13, 17, and 21 mm and they designate them in their part #'s by numbering them 1 (thinnest), 2, 3, 4, and 5 (thickest). The pads installed on a particular car are based on the equipment that came with that car. For example, a fully equipped 2002 CLK430 convertible probably has a different spring pad than a base 1998 CLK320 coupe. You can reach in and feel the number of bumps on the pad to determine which one your car currently has. The number of bumps will match the pad number.
Front:
210-321-01-84 5mm
210-321-02-84 9mm
210-321-03-84 13mm
210-321-04-84 17mm
210-321-05-84 21mm
Rear:
210-325-01-84 5mm
210-325-02-84 9mm
210-325-03-84 13mm
210-325-04-84 17mm
210-325-05-84 21mm
The difference from the #1 to the #5 is 16 millimeters or .63 inches. I hope that helps.
Front:
210-321-01-84 5mm
210-321-02-84 9mm
210-321-03-84 13mm
210-321-04-84 17mm
210-321-05-84 21mm
Rear:
210-325-01-84 5mm
210-325-02-84 9mm
210-325-03-84 13mm
210-325-04-84 17mm
210-325-05-84 21mm
