HEELLLPPPP!!!!
Old Feb 5, 2010 | 04:51 PM
jajara's Avatar
CLA45 C63 SL63 CLK BS C BS SL600 560SEC 500E
HEELLLPPPP!!!!
Heavy rain in florida today, well as i drove off where my cabin filter is LOTS of water wtf is that, can someone help me with pics PLEASEEEEEEE!!!!
Old Feb 5, 2010 | 06:50 PM
gregory13lil's Avatar
2000 CLK430
Man...these are symptoms of the water drain tube being blocked. The tube or drain is located under the cover that is at the bottom of the winshield. There is a drain there (I cant remember which side) that if blocked will leak right into the passenger side footwell area. One of the posts stated the you could actually clear the blocked hole area without taking the cover off. BUT...the drain will get blocked again so it is recommended to take the cover off and completely clear the drain of all leaves and debris so that it can drain all the water to under the car instead of the footwell.
FOUND AN AWESOME LINK that has info on your problem: https://mbworld.org/forums/clk-class...-footwell.html
Greg
Old Feb 5, 2010 | 07:29 PM
sick430's Avatar
CLK Cabrio
mine kept leaking even though it was clear of leaves and dirt. there is a little flap at the bottom of the drain that i figured must be sticking even though i could flip it open with my finger, so i ripped that sucker right off! never leaked since!
Old Feb 6, 2010 | 03:58 PM
jajara's Avatar
THank you guys so much i am going to do it right now....
