Sunroof Problem
Old Feb 27, 2010 | 08:03 PM
320ibimmer's Avatar
CLK430
Question Sunroof Problem
My CLK430 sunroof opens fine but when you close it it hangs up and won't fully shut. I've lubed the rails and any other moving parts and there's no change. Has anyone encountered this or have any suggestions on what could be wrong?
Thanks for any help!
Old Feb 27, 2010 | 11:23 PM
MarcusF's Avatar
2002 CLK430
A picture is worth a thousand words, but I’m going to hope this works without me having to grab the SLR. Standing outside the car, on the driver’s side door jamb, with the sunroof open, looking down at the hole in the roof where the sunroof would be if it were closed – you can see your sunroof rides on rails. There is one rail, with a slot down the center, on either side of the sunroof.
Looking toward the front of the rail that's closest to you, just to the outside of it (toward you), there is a guide. Make sure the front of that guide (toward the front of the car), is pushed inward, (away from you, toward the center of the car). The passenger side has a guide as well. Reach over and make sure the front of that guide is pulled inward (toward you, toward the center of the car). Now the sunroof should work fine.
Those guides pull the sunroof wind deflector down. If out of position, the sunroof hits something (the deflector?) and stops. If this makes absolutely no sense, post back and I'll take a picture.
Old Feb 28, 2010 | 06:24 PM
falls profet's Avatar
Sorry Marcus, but when you get a chance could you post some pics? I think I understand what you're saying, but I just want to be certain.
My sunroof will slide closed just fine, but when I try to open it, it will stop on occasion and I have to keep hitting the buttom for it to open.
Old Feb 28, 2010 | 08:03 PM
MarcusF's Avatar
2002 CLK430
The two attached photos (two angles of the drivers side part) show the part I meant. There is another one on the passenger side. Press that one toward the center of the car.
When my sunroof jammed it did what you (falls profet) are describing.
Press the button and it will back up tow inches, then stop. Press the button again, another two inches, then stop again. The problem was corrected by pushing the parts described inward.
Now, does anyone know how to tighten them? I hope the words 'remove headliner' are not part of the answer.
Attached Thumbnails Sunroof Problem-sunroof-001.jpg   Sunroof Problem-sunroof-002.jpg
Old Feb 28, 2010 | 09:01 PM
dlbehrns's Avatar
99CLK320,
I didn't have a problem with my sunroof closing those last few inches but jamming in the middle. I used a spray silicon lube but it never really solved the problem. any recommendations for the proper lubricant?
Old Mar 1, 2010 | 11:42 AM
I greatly appreciate it, buddy! I'll do that this evening when I get home.
Yeah...that stopping every 2 seconds is quite annoying. I thought that the motor might be going out, but I'm glad you had the same issue and resolved it this way.
Thanks again, Sir.
Old Mar 2, 2010 | 01:01 AM
MarcusF's Avatar
2002 CLK430
I've used white lithium grease (in the tub, not spray), but I'm not sure it's proper. In the 1990's MB used to recommend 001 989 46 51 for the sunroof. I have no idea what's in it, but "it" costs $77 per tube, tub, or however they package it. Lastly, no mention of that part number in the 2002 Factory Approved Service Products guide. They mention Castrol LM grease for multi-purpose tasks. Castrol LM is lithium grease.
Old Mar 3, 2010 | 08:34 AM
Sam34's Avatar
W208 230K MY2000
Some times ago, I had the same problem. I did exactly what MarcusF has perfectly described.
Ciao
Sam
Old Mar 3, 2010 | 10:58 PM
dlbehrns's Avatar
99CLK320,
Castrol LM
I found this on ebay but it can't be right?
http://cgi.ebay.com/Castrol-LM-Greas...item3ef84bd157
it would take forever to use it all.
Old Mar 16, 2010 | 11:16 PM
dlbehrns's Avatar
99CLK320,
Castrol LM
Can anyone post a link for this stuff in the US? I can find it on the web in the US but not here. TIA. dlb
Old Mar 17, 2010 | 12:33 AM
MarcusF's Avatar
2002 CLK430
http://www.amazon.com/s/ref=nb_sb_ss...sprefix=white+
I buy it by the tub. 16oz for $5. Pep Boys & WalMart carry it.
Old Mar 22, 2010 | 07:29 PM
BRTrunner3650's Avatar
CLK430
Sunroof
wanted to thank everyone for their post my sunroof started experiencing similar problems today. I just arrived at my condo and it was about to down pour. I found this website, became a member, found this thread, and saved my car from the storm.
Mucho Gracias!!!
Old Mar 22, 2010 | 08:16 PM
tomtomtomtom's Avatar
02clk55///2010GLK350
Hope that the greasing will work. I had a '99 that had the problems described. It was still under warranty and after greasing etc..two trips to the dealer, they found that the linkage had a slight bend. Rather than try to bend it, they replaced it. Worked perfectly from then. If it was out of warranty, I would try a slight bend to see if it helps.
Old Mar 22, 2010 | 09:58 PM
dlbehrns's Avatar
99CLK320,
Thanks Marcus but I was looking for the Castrol stuff in the US. But a tube of another brand would work. You know what they say? "A little dab will do yah."
Old Jun 24, 2011 | 03:53 AM
phrankster26's Avatar
CLK430
Thanks MarcusF
I just wanted to say SUPER THANK YOU to MarcusF for the detailed pics and information to fix my CLK430 sunroof problems. I did exactly as you described, and my sunroof now closes with no problems! You saved me tons of time and $$$.
I really admire that you took the time to post the solution and include detailed photos for troubled MB owners, like myself.
thx again!
Old Nov 19, 2012 | 12:53 AM
maui's Avatar
2001 E430 Sport 34K, 2002 E320 (38K) ,1999 CLK320, sold, 2003 BMW 540ia (26K) sold
Ok Marcus found the thread and the pics. Thanks for you efforts. For the record did search for most topics you reviewed but did not advance search by name...
Looked on EPC for a parts diagram and found what is described as a left and right baffle part # A 208 784 01 70 left, and 02 70 right
Not sure they are the parts I need unless the pics are not quite accurate. Amazing how cheaply these guides are made. The metal is uber thin and appears plastic coated, kind of like an afterthought. Never seen such a cheaply designed part from Mercedes...
Old Jul 12, 2014 | 12:02 PM
Aleyda's Avatar
mercedes clk 430
Hi Marcus have a 2002 Clk 430 same issue with the sunroof not closing all the way follow the instruction and still does not close. Any other option?
Old Jul 13, 2014 | 01:18 AM
MarcusF's Avatar
2002 CLK430
A couple of tricks have come up in the past two years. Does the roof stop at the point where the wind deflector is supposed to close? If so, does the roof close completely if the wind deflector is manually closed? If yes-yes, there is a 25 cent fix, but let me know because I'd prefer not to take photos of a fix that doesn't apply.
Old Aug 6, 2014 | 03:50 PM
njgilligan's Avatar
2001 CLK55
That describes my situation exactly. I just lubricated the rails and wind deflector guide arms. I also adjusted the arms as you suggested, but still no luck. I'm curious about your $0.25 fix...
Old Apr 22, 2015 | 12:21 PM
SuperChargerE55's Avatar
E55 AMG V8 Kompressor 2004 E 55 AMG Type: 5,439 cc (5.439 L; 331.9 cu in) Supercharged V8 Powe
No need for loosen the screw first?
I know is an old post but just wondering, well need advise on this, do you loose the bolt/screw first or? Should it be possible to push the part inward without any resistance? I mean if it can move freely like that maybe that is the problem?
will try it mine get stuck once in a while at the wind-deflector so annoying, and yes no removing the deflector hahahaha but what a damn noise one will get when driving, I cant believe it I seen the advice to mate so insane, I hope that guy enjoys driving with open sunroof now haahaha..
Old Nov 7, 2016 | 06:52 PM
AmyAndrews's Avatar
2000 VW Beetle
Sunroof stuck at wind deflector
My sunroof is stuck right at where the wind deflector arm is. It won't open or close from this point. When I try to open or close it, it starts to close, gets stuck about two inches from closing and then opens to about 3-4 inches. When I manually hold the wind deflector down, it still does this. Any suggestions?
Old Nov 7, 2016 | 09:28 PM
Have you tried just hold the close button I mean keep holding it?
If not try close it using manual method. I remember mine did that to once in a while hate it but this used to fix it
Old Nov 7, 2016 | 10:18 PM
AmyAndrews's Avatar
2000 VW Beetle
There's no button, it's a dial and no matter where you turn it, it does the same thing. When I try to manually close it, it won't budge. It's like it "thinks" there's something caught in it, but there's not. It appears to be on track. I'm thinking the shade may have something to do with it, it's stuck all the way to the back. The way the sunroof is stuck, I can't get to the back bolts to to get the sunroof off.
Old Nov 7, 2016 | 10:50 PM
I meant the close / open button. Or is it not original sunroof if not I ccan tthen sorry. But the oioriginal sunroof open close with button push it keep holding the close button even u tthink is not working keep holding it. When had my clk mimine did it to once in a while
Old Oct 6, 2021 | 12:28 AM
strider-g3's Avatar
87 420sel, 91 560sec, 02 S55 AMG, 09 A4 3.2, 14 Outback, 12 Focus SE
THIS WORKED ON MY CLK55 2001. IT WAS STUCK OPEN FOR WEEKS AND I TRIED ALL THE DIFFERENT RESET TECHNIQUES.
WHAT I HAD TO DO WAS PUSH THE ADJUSTABLE PART TOWARDS THE OTHER DIRECTION AND THEN PUSH IT INWARDS AS SHOWN IN THE PICTURE!
THANK YOU!!!!!!!!!!!!!
