touch screen stereo?
Old Mar 4, 2010 | 12:14 AM
J_CLK_G's Avatar
1998 CLK320
i would like to put a double din touch screen into my 98' clk. besides the unit, do i just need the wiring harness and im good to go? if not, what else should i need? also, can i use my stock 6cd changer?
Old Mar 4, 2010 | 01:45 AM
MarcusF's Avatar
2002 CLK430
If your new head unit has a fiber optic port (never seen an aftermarket one with the fiber port), then you can use the OEM 6-disc changer. If your carhas Bose amps, do you plan on using the amps and speakers, or running new amps/speakers/wiring?
Old Mar 4, 2010 | 12:49 PM
J_CLK_G's Avatar
1998 CLK320
yes i have bose system, but would like to hook up my amp and subs as well (will keep speakers stock)...which wiring harness can i use? ive heard the vw/audi harnesses work.
Old Mar 5, 2010 | 01:19 AM
MarcusF's Avatar
2002 CLK430
The Crutchfield part number for the wiring harness adapter is 120701784. It's free if you buy your headunit from them, or $12 if purchased separately. This is the link.
Bose uses a balanced, differential signal interconnection. To use a head unit with an unbalanced connection, you'll need a converter. PAC makes a box that will convert the signal. You can use the RCA outs for the extra subs and amps.
Old Mar 5, 2010 | 08:25 AM
jajara's Avatar
CLA45 C63 SL63 CLK BS C BS SL600 560SEC 500E
there is no way that u use cdc on aftermarket unit, and think about shifter in the way...
(i did it recently and its sucks)
