Lowering Questions?
Old Mar 22, 2010 | 11:19 PM
rjlawlor646's Avatar
2001 CLK 320
Lowering Questions?
This summer I mill be lowering my car. It has 130000 miles and i live in new england so its exposed to a lot of salt and stuff. Is there anything i should look out for or prepare for before i start the project? Thanks!
Old Mar 23, 2010 | 12:31 PM
mint's Avatar
2013 FIAT Abarth 500
I think the most standard setup for lowering is H&R sport springs and Bilstein sport shocks.
Also, depending if you get bigger wheels & tires, an adjustable rear camber kit.
Old Mar 23, 2010 | 04:59 PM
localpimpn's Avatar
+1
Consider Koni shocks also. They are adjustable and have a lifetime warrantee. I used H&R springs with Koni's.
Old Mar 24, 2010 | 05:35 PM
2001 CLK 320
Thanks, i was guna do 18's, do you think those would still require a camber kit?
Old Mar 24, 2010 | 07:16 PM
mint's Avatar
Originally Posted by localpimpn
+1
I hear a lot of guys say they prefer Bilstein over Koni because the ride is a lot harsher with the Koni Yellows; again, that's only what seems to be the general MB consensus.
I would recommend it. The bigger the wheels and lower you go, the more negative camber you're going to get; you could opt not to install a camber kit but I just think it's easier since your installer will be pulling your wheels anyways.
With 18's it probably won't be too bad but I think anytime you make a suspension adjustment especially lowering, an adjustable camber kit is a good idea.
