SS brake lines, front only = soft pedal?
Old Apr 19, 2010 | 01:56 AM
GiZzO's Avatar
CLK55 / E350 Coupe
Easy question if i just replace the front lines to SS and not rear. Due that the rear lines will expand will i be defeating the purpose of going SS lines?
Old Apr 20, 2010 | 12:58 AM
MarcusF's Avatar
2002 CLK430
If the rear lines are swelling, they're bad. If none of your lines are swelling, you may not notice the difference between SS and OEM.
Old Apr 20, 2010 | 12:37 PM
dlbehrns's Avatar
99CLK320,
did you bleed the fronts after replacing the lines?
Old Apr 21, 2010 | 11:45 AM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
Quick answer: No. Be sure you bleed all 4 corners even though you only replaced the front lines.
