cps
Old Apr 19, 2010 | 07:24 PM
maxxwell22's Avatar
clk 430
cps
Camshaft or crankshaft position sensor, what does this thing exactly do. Will it cause your car to stall, die, Then hard to restart.
Old Apr 20, 2010 | 01:13 AM
MarcusF's Avatar
2002 CLK430
A crankshaft position sensor tells the ECU the position of the crankshaft. This is commonly referred to as the CPS. If the ECU doesn’t receive a signal from the CPS, programming logic tells it the engine isn’t running, so fuel and spark are disabled. The lack of fuel and spark are why the engine stops running and won’t restart.
Old Apr 20, 2010 | 07:43 AM
maxxwell22's Avatar
clk 430
Can i change this sensor myself, or will it require more technical expertise. I try to do most car work myself, but never owned a benz. I hear its located down on the side of the tranny , and requires a long extention to reach.... I use to work on aircraft in the Air Force... so I'll give it a try with a little hints from you guys.
Old Apr 20, 2010 | 12:35 PM
dlbehrns's Avatar
99CLK320,
yes you can replace the CPS yourself. Look under the DIY thread and there should be some pics there. the CPS is located down behind the driver's side head at the back of the engine and may actually be on the bell housing. I've not eyeballed it myself but have looked at the pics and if I remember correclty it takes a #8 torques socket. anybody out there correct the socket size?
Old Apr 20, 2010 | 03:34 PM
maxxwell22's Avatar
clk 430
The picture on this site is very small. But i see what it looks like from a pic on ebay. They sell it for $68 plus 12.95 shipping. I'll have to order it and pray this works, but from the threads here, it seems to be the thing to fix. Thanks.
Old Apr 20, 2010 | 05:20 PM
MMM430's Avatar
'00 CLK430 & '08 Lexus RX 350
Buy yours here and save a few bucks. Several of us have had the problem. Its certainly a DIY. http://www.autohausaz.com/search/pro...ition%20Sensor
Old Apr 20, 2010 | 06:19 PM
maxxwell22's Avatar
clk 430
Thanks for the info, i was hoping someone had a cheaper price, thanks. I looked under the hood for the sensor, haven't seen it yet, but i will, when i have something to go by.
Old Apr 20, 2010 | 09:43 PM
MMM430's Avatar
Best DIY pics for CPS replacement Ive seen!
http://pingelblog.blogspot.com/2008/...on-sensor.html
