Question about spacers?
http://www.alloywheelsdirect.net/inf.../mercedes-benz
And for offset calculations:
http://www.1010tires.com/WheelOffsetCalculator.asp
With your 20mm spacers, I think your back wheels may extend past the guards. anyway, good luck with them and do post some pics when you're done.
depends if u want my car so low and depends if u want to roll the fender and what not.
i slammed mine to the max and im using 15mm.. 20mm it will rub on mine
I have 35ET with 9.5J and I could go to 20mm spacers but I have just got 18mm on. I have also rolled my rear fender.
I would get that done first before you size up into spacers.
What fits now won't fit later after your car is adjusted back to spec.
Somehow the H&R and all the ebay BENZ 10mm spacers that have a raised hubcentric center, will not fit onto the W208 brake rotor on the front.
Cheers!
