Suspension question
Old May 19, 2010 | 09:56 AM
1998CLK320's Avatar
1998 CLK 320
Suspension question
I am getting my rear lower inner and outer bushings replaced to stop a squeaking noise.
what else should I replace?
The ball joints I was thinking and I don't know.
My Indy also told me the control arm is fine.
Old May 19, 2010 | 10:23 AM
saboli's Avatar
99 clk320
I just changed the tie rod end and wheel bearing hub and solved the problem. If the ball joints are fine you dont need to change them.
Old May 19, 2010 | 12:56 PM
1998CLK320's Avatar
1998 CLK 320
Would the control arm have both inner and outer bushings?
Old May 21, 2010 | 01:17 AM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
no just inners... front and rear. It's the rear one that most seem to replace
Old May 22, 2010 | 02:26 AM
jbenz99's Avatar
Sold 2003 CLK 500,2003 SL 500,2006 Acura MDX,1998 BMW M3 convertible
just replace what broken and you be fine
