sealed trannys???
Check http://www.alldata.com/TSB/35/9935AW88.html while you are at it for any other possible problems.
The good news is, you still CAN have your tranny fluids changed by MB if you insisted on it, I don't believe it would of lasted 100,000 miles with out a cjange anyways... And that might solve your problem, it could just be slipping a little.
The bad news is, if you do not have warranty, your bill will run up to as high as $2500 for new sensors, new ECU, and lots of other stuff...
My problem was solved by new ECU and new tranny fluid, but I actually just got the car back for 2 days, and it has not happened yet.... so time will tell....
Thanks God I bought the extended warranty!!!
