Passenger Mirror
Details have been covered in several prior threads.
Tilt mirror forward, remove retaining wire, pull mirror off and remove wire.
Install in reverse.
When you are ready to install, lift the silver retainer wire so it is "caught" on top of the small center tab. Position the mirror, then, with a small screwdriver, release thespring clip and it will lock in place. (You may have to repeat this a couple of times until it is perfectly aligned and SECURELY locks in place.)
