DYNO Results - CLK320 Hi Flow Exhaust Manifolds / V6 Headers
Dyno was with the 20" heavy chrome so you know it will be allot more with 2 changing factors.
1. Dyno without the 20's
2. Dyno at a regular shop with regular Dyno wheel rollers.
Can't wait for PowerChip Tokyo to open in October to have my ECU tuned.
After my ECU being tuned I may consider two other options.
1. Have my heads polished and increased to 3.8liter with maybe a renntec camshaft
2. Supercharger
Dyno Explanation
File1 (Red Line) - Dyno with 20's before KMACs
File2 (Green Line) - Dyno with 20's after KMACs and Evo Pulley
File3 (Blue Line) - Dyno with 20's with new custom Headers
Sound did not change in decibels but did change in frequency dropping by about 20Hz.
Unofficially
HP increase +7
Torque increase +28 = 16% Increase
I say this is unofficial because I went to a tuning shop that has heavier Dyno rollers than normal because they said they want to test actual road resistance. With that being said here are the numbers
Before
165.11 RWHP @ 171.42 lb-ft torque
After
172.01 RWHP @ 199.63 lb-ft torque
Even before the Dyno driving home from the shop, I noticed smooth consistent acceleration. From a stand still you feel a tingle of enjoyment in the 1K rpm range and while rolling driving moderately you feel it around 2K, and a some aggression around 2.5K and increasingly becomes a monster in the 3-5K range.
MB Original CLK 320 Engine Specs
Horsepower @ rpm = 215 @ 5,700
Torque (lbs-ft.) @ rpm = 229 @ 3,000-4,600
Wheel/Tires = 7.0x16-inch 205/55R16
More information can be found here from this Guy
http://www.marcusfitzhugh.com/CLK/spec.html
2. Supercharger
Dyno Explanation
Unofficially
HP increase +7
Before
After
CLK W208
Ghost's designs are flawless, and i really mean that i love the camber kit i just wish he would make a set for the front, because my back tires are still brand new while it's time to change the front ones already and i put all 4 at the same time when i installed the camber kit. Gohst how would i get rid of the squeek? if i wasn't changing my egine i would get the headers. by the way i gt my car back full time again so i'llbe back here more often and i have a couple of new suprises that Will has already seen one of them.
CLK55 / E350 Coupe
Ash,
I just hosed the ends with lithium grease its been good for 2 weeks now. Works for now until the revision.
sprayed my rear camber arms with white lithium grease also. and have been squeak free for about 2 weeks too! its so nice to have it gone!
Ghost, is it possible to make the header like the kleeman one where we can remove the primary cats and plug the sensor in the headers?????
99CLK320,
I exchanged numerous emails w/Kleeman. they eliminate the O2 sensors and do a chip tune to completely eliminate the sensor readings from the mapping. I could be wrong but that is how I remember it. Kleeman's long tube headers were $1500 which included the chip tune plus $600 to install. Ghost has done a great job and kept the price down. I will get to shake his hand this weekend when I pick mine up. {;o)
if i still had my job, i would have bought the headers from him by now and i will as soon as i start new job.
