Rear Shock bar
Old Aug 18, 2010 | 11:15 AM
SoCalw11w123's Avatar
Rear Shock bar
Can anyone post pics of their Rear Shock-brace Bar?
Im looking to see the final results installed...
also where did you get them?
thanks in advance,
ELI
Old Aug 18, 2010 | 11:45 AM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
u mean strut brace from VIPclk?
Old Aug 28, 2010 | 11:16 AM
ppic's Avatar
E63 2010
I seach for years to find commercial bar. I finally made them see:https://mbworld.org/forums/w210-amg/...r-project.html. The final result is pretty clean.
Attached Thumbnails Rear Shock bar-img00091-20100828-1103.jpg   Rear Shock bar-img00093-20100828-1103.jpg
Old Aug 28, 2010 | 11:23 AM
dlbehrns's Avatar
99CLK320,
the only difference between yours and VIPclk320's is his is in two pieces. in the center of his is an adjuster with regular threads on one side and reverse threads on the other so that when you rotate the center piece you can tighten or loosen the bar. the tighter the bar the stiffer the ride and so forth.
Old Aug 28, 2010 | 12:33 PM
ppic's Avatar
E63 2010
In fact the tie rod end are one left hand and one right hand thread. There is key drive on the bar. I based my drawing on VIPclk320 (thank's), only the fixture is different.
Old Aug 28, 2010 | 06:08 PM
jbenz2001's Avatar
2001 clk 320
Nice work,how does it handle now that u installed it?
Old Aug 30, 2010 | 09:08 AM
ppic's Avatar
E63 2010
Improve the handling more than expected. The understeer is reduce by 10-15% and inner rear wheel spin in turn too. Very efficient at the track, in normal life, you have to drive very enthusiasticly to reach the breakpoint.
