What is this EC button on my climate control (2001 CLK430)?
2002 CLK55 AMG 2002 c230k 02 Triumph America 1992 300e
Everything looks normal except number 07. Thats the barometric pressure of the Freon. Mine reads double that number. My guess is that you're low on freon. When you have someone charge the system, ask them to add dye. That way if there is a leak in the system they'll be able to spot it. If there isn't a leak, the AC will probably work fine after the charge. If there is a slow leak, the AC will work fine until the freon gets low again in a few days (or weeks). By adding dye, they'll be able to spot where the freon is leaking from "if" you have to bring it back.
I got that 1 is cabin temp and 7 is freon pressure. what are the other 2-8 codes for?? Also does this work like the old w202s where you can check the voltage and so on?
PS to that person who will say "who are you talking to" .... " the thread is 5 years old" keep in mind your prob the same person that would say search "AC" if I were to just ask a question as a new thread.......
Btw the maker of this video "fupabox" on youtube makes a lot of good detailed vids on his w202 as we all know mercedes functions and technologies are all variants of the past which is great for repeat merc owners.
funny story..... when I went to buy my 02 C230K, The Husband and Wife didn't know how to turn, well i guess pull on the fog lamps but since my w124 it has been the same way through the years..... just an FYI
2000 Mercedes Benz Clk 320
http://www.marcusfitzhugh.com/CLK/DIY/acdiag.html
I found that link particularly helpful when I my EC light stuck "on". So my story was I bought the car in the winter, and randomly the EC button stayed on, never payed attention to it since it was the winter time. In the summer when I addressed the problem I searched high and low for a solution, eventually I learned through various posts on how to read the error codes and what not, turned out I had low freeon. So I bought the freeon charging kit and charged it, lasted about a month then it the light came on again. Recharged it properly this time and haven't had an an issue since. My suggestion is if you have low freeon, follow all the steps CAREFULLY on the can, it'll make it worth it in the end.
Hope that helps a bit. Also, you're probably going to have to reset the unit a few times because for me after it was charged and everything the light came back after a few starts and after some resetting it eventually went away.
Clk-320 AC not working
Good day
My AC isn't working and the garage has check the Freon and it's full
EC light always stays on
I have run true the AC diagnostic mode on my Mercedes CLK-320 2000
Here's the number i got
1-25
43-14
42-248
41-5
40-8
24-14.1
23-0
22-0
21-6
20-0
10-0
9-0
8-30
7-8
6-89
5-33
4-33
3-36
2-23
Regards
1-25
43-14
42-248
41-5
40-8
24-14.1
23-0
22-0
21-6
20-0
10-0
9-0
8-30
7-8
6-89
5-33
4-33
3-36
2-23
Regards
@Cardy, don't take this the wrong way, but this is a good example of why people should fill out their profile or say something about where they're located
If this is a US spec car, the engine hasn't warmed up, it's 23 degrees Fahrenheit outside and 25 degrees Fahrenheit in the car . Both heater cores are almost frozen and the evaporator dryer is as cold as you can expect.
I'm going to guess this is an ROW car and that its really closer to 74F outside, 77F inside, and the heater cores are hot; 91F and 97F. That's the problem, the duovalve isn't functioning properly. This page will tell you how to fix them. If cleaning doesn't fix them, in the U.S. they are about $300.
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
#33
All codes are 5 digits in length. I'm going to guess your B241 is a B1241, which means low Freon. That is confirmed by #7 which is the Freon pressure, and 4 is low.
#35
The EC light does not prevent the system from being charged, The EC light is on because the system needs Freon. I would have the system charged and ask that they add dye. This will allow the tech to determine where it's leaking - if Freon is escaping at a perceptible level. It could be the system hasn't been charged since new and a simple top off is all it needs.
#36
BMW 318IC, Mercedes Benz Slk
in my experience
Without doing any diagnostic work on your Benz, I believe that you have a relay that is sticking in the closed position. Replacing the relay is very simple and is around $30 for the relay.. keep in mind that you can pick a relay up at any import salvage yard for a few bucks, just make sure you copy down the part number from the top of the old relay and get a relay with the exact same number or call Mercedes and get them to cross reference the number for an aftermarket or substitute relay. your owners manual will show the location of the relay in your vehicle... let me know if that takes care of the issue..if not I will walk you through a few tests to diagnose the problem without having to pay $130.00 labor to Benz!
#38
ac clutch relay
My ac right now is ghetto rigged I have the ac clutch jumped straight to the power. My system has Freon no leaks, my compressor obviously works my uncle and I believe that the ac clutch/compressor relay may be bad however we can't find figure out witch relay goes to the compressor/clutch. Does any one know? Also can anyone tell me about ac diagnostics. My numbers are
1. 92
2 99,83
3. 110,105
4. 112,108
5. 104,101
6. 203,201
7. 9
8. 151,149
9. 0
10. 1.5
Skips to 20
20. 0
21. 6
22. 0
23. 0
24. 14.0
Skips to 40
40. 8
41. 5
42. 232
43. 14
1. 92
2 99,83
3. 110,105
4. 112,108
5. 104,101
6. 203,201
7. 9
8. 151,149
9. 0
10. 1.5
Skips to 20
20. 0
21. 6
22. 0
23. 0
24. 14.0
Skips to 40
40. 8
41. 5
42. 232
43. 14
#40
I have a 00” clk430
If this is a US spec car, the engine hasn't warmed up, it's 23 degrees Fahrenheit outside and 25 degrees Fahrenheit in the car . Both heater cores are almost frozen and the evaporator dryer is as cold as you can expect.![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
2000 CLK 430 $500
Battery $200
Spark Plugs $200
A/C Recharge $60
1 / 107
2 / 136
3 / 76
4 / 76
5 / 72
6 / 205
7 / 13
8 / 131
#42
01 clk430 ac blows room temp. HELP
Start the car, but do not touch the gas. Let it idle in park. Turn on the AC. Press and hold the "REST" button on the climate control. After approximately 5 seconds, the display on the climate control will change. After the display changes, you can let go of the REST button. What have just done is put the AC in diagnostics mode. On the climate control display, you will see 1 on the left, and another number on the right. Write down both numbers. Press the AUTO button on the left side. That will cause the number on the left in the display to change to 2, with a different number on the right. Write down both numbers again. Continue to do this until you have numbers 1 through 8 (on the left) and the corresponding numbers on the right side of the display written down. You can press the REST button again after you have written the numbers down. Pressing the REST button again will take the AC out of diagnostics mode. Post the numbers you wrote down here, and I’ll take a stab at telling you why the AC isn’t working.
2 66
3 71
4 71
5 69
6 99
7 5
8 66
9 0
10 5.1
20 0
