HELP!! spilt liquid on the center console and in the shifter
, then when i went to go home the car wouldn't start for about 10 mins then when it started the dash lights where flashing etc. I noticed i couldn't take it out of park but i knew about the release button for the shifter. I drove it home in LIMP mode in 1st gear and dried it out the best i could, so now im not getting any warning light faults but im still stuck in park and in LIMP mode. Im thinking it could be the shifter unit thats messed up but what do i know
HELP!!!!
Check the DIY here in the forum.
The cost, if an issue, is far less than what the dealer will charge for new and labor.
The replacement is really straight forward and very easy. Figure first time under 30 minutes.
Just disconnect battery before removing any electrical parts like the shifter and unplugging the wiring and reconnect before hooking the battery back up
Good Luck.
