Adjusting Halo Projectors--does this look right ?
A little history. I hit a deer, so replaced front end sheet metal, bumper cover, etc.. the stock headlamp was $300+ a side/each. These aftermarket projectors were less than $300 for the pair.
Back to the projectors.
I have absolutely no experience with these types of headlamps, and have only found vague info regarding adjusting these things. I have found the bottle cap knobs that allow for adjusting the vertical and horizontal axes, and have taken a shot at adjusting them. Of course, I don't know what I doing.
The light cast onto my garage door, from each side (each headlamp) is horizontal, and then the light angles upwards on the passenger side. You can see the sharp angle of the light rising upwards, as it is cast on the garage doors.
Is this rising angle normal for projectors ?
Can the inner lenses be rotated ?
I include images of the cast light with the low beams and the high beams. Is this what they are supposed to look like, or what ?
Link:
http://www.danielsternlighting.com/images/Aim.pdf
