Battery Questions
Old Dec 12, 2010 | 12:15 AM
Mslaughter's Avatar
Brilliant Silver CLK 320
Battery Questions
I recently bought a '99 CLK 320 but it did not come with an owner's manual, I ordered one online but it hasn't arrived yet...
Anyways, I have a few questions about the battery and charging system on our W208's, it's supposed to drop down to the single digits this week so I want to be prepared incase something happens, I did some searching around but I still have a few questions.
1. Does the car have just the 1 battery in the trunk?
2. If the battery dies, what all do I need to reset? Windows, sunroof, seats fore/aft, anything else?
3. Is it possible to jump start the car from another car? I have Michelin smart cables which are supposed to prevent electrical spikes.
https://www.buysmartcables.com/
I feel like a newbie asking all these questions but without an owner's manual yet I'm somewhat at a loss, thanks.
Old Dec 12, 2010 | 08:27 AM
Serndipity's Avatar
2001 CLK320 Cabrio
These same questions have been asked many time and using the boards 'search' facility would provide additional details.
The Mercedes-USA site has owner manuals 'free' to download.
Yes
Yes, the ABS system (by fully turning the steering wheel in each direction).
Yes, via the trunk battery terminals or a terminal in the engine compartment.
Old Dec 13, 2010 | 01:52 PM
Mslaughter's Avatar
Thank you for your help Serndipity, I check MB's site and they only provide 2000 - current owner's manuals available for download. One more question, is it possible to have the doors locked without the alarm active? If I press the anti-tow switch will that disable the alarm under all circumstances? Or, should I manually lock it with the pins to keep the alarm off? I'm storing the car for the winter, it will be in a safe place but I would still like to have it locked without the alarm active, as I feel it will be an unnecessary drain on the battery. Thank you again.
Old Dec 13, 2010 | 03:12 PM
mint's Avatar
2013 FIAT Abarth 500
As far as I know, doors locked = alarm active. I have no idea how or why the doors would lock without enabling the alarm.
Anti-tow button off = any vertical movement of the chassis will enable the alarm; alternatively, if the tow-switch is on then if the doors are locked and the car is placed on a flatbed or the tow hook on the rear or front is used the alarm will not go off. I haven't tried it, but I'm thinking the alarm will still go off if the doors are broken into/glass broken even if the tow switch is on.
