steering wheel vibration at 40mph
2002 CLK430
I've done the tie rod assembly, steering damper, idler arm repair kit, new front bearings and new tires to boot. The steering is much better but I have a slight vibration through the steering wheel at 40mph. It used to vibrate worse but now only at 38-42mph and it is slight. Any idea on what this could be? I don't believe the races were replaced when the bearings were done, that's about all I got. Any help is appreciated. It's a 2002 430CLK at 77k miles
2000 CLK430
Ohhh you said new tires so I am sure you had a good balance but had to ask anway.. Did you balance all 4 rims?
Greg
2002 CLK430
I replaced my bearings without doing the races and I still had a vibration so I had a shop push out the races and replace them for me. After replacement my slight vibration went away. My races could have been worse than yours is but I was told to always replace them when doing the bearings.
Greg
Greg
2002 CLK430
