Brake Caliper Stuck
Tried to replace the brake pads and rotors today but ran across a problem..
Front passenger corner, after removing the pin covers(2) , pins(2) and the sensor, the caliper wouldn't lift from the original position.
It was loose enough to wiggle around, but even after a rubber mallet and a bit of leveraging, it still wouldn't detach..
Any suggestions on disassembly?
Thank you in advance.
How about Kobe's dunk! And Duncan's block on BronBron.
Can you guys point it out for me in these tutorial pics?
https://mbworld.org/forums/e-class-w...brake-job.html
I want to be sure I can locate it before I take the wheel off again.
Cheers
The Knicks and the Heat in 90 minutes. Melo and BronBron is always a good show!
To note.. Tirerack is clearing out some of their brake pads. Seems to be some good deals.
I used:
Brembo rotors
Akebono front pads
Satisfied Pro rear pads
and not a squeak so far
