Vibration at 40mph - help
Old Feb 25, 2011 | 05:34 PM
787's Avatar
787
2002 CLK430
I feel a vibration in the steering wheel at 40 mph. I have done things that have improved it as well as tightened up the cars handling. New lower ball joints, new tie rods (drag link), idler arm repair kit, new bearings and races, new alignment and the rotors were balanced as well. Then I put on new tires and one new wheel as it needed a fair amount of weight to balance and I didn't trust it. All is good but a slight vibration felt through the steering at 40mph. Any advice, getting a little frustrated and broke.
Old Feb 25, 2011 | 06:51 PM
MoReace's Avatar
Often when you start to feel vibrations at 40+ (and it continues to get worse at higher speeds), then you:
1) have a bent rim (I ruined more than 1 rim with today's pot holes)
2) are out of alignment
Good luck
Old Feb 25, 2011 | 08:19 PM
787's Avatar
787
2002 CLK430
I should of been more clear. The vibration is at 38 to 42MPH, no other speeds. odd one
Old Feb 26, 2011 | 08:08 AM
Chappy's Avatar
AMG
Could be the tires....what are you running now?
Also, have you replaced your steering damper?
Old Feb 27, 2011 | 12:01 AM
787's Avatar
787
2002 CLK430
The tires are new, Hankook Ventus Evo V12, or something like that. The vibration was before and after the new tires, no change. I did not replace the steering damper though, could that help?
Old Sep 16, 2023 | 12:18 AM
quik55's Avatar
2000 ML55 AMG 2001 CLK55 AMG coupe 2002 CLK55 AMG Cabriolet 2025 BMW M2 6MT
Ever figure this out 😂😂
