Wheel question
Old Mar 6, 2011 | 09:36 PM
dlbehrns's Avatar
99CLK320,
Wheel question
Is anybody out there running a 9" wide rim with a 30 mm offset on the front of their clk? I'm lowering the car on Vogtlands and I'm thinking these are too wide without rolling the fenders. I think they will fit in the back but don't think they will make it on the front. I tried an offset calculator comparing oem to the new rim and it tells me I have 20mm less clearance on the inside and the outside would EXTEND an extra 30mm. Whoa! Anybody?
Old Mar 7, 2011 | 01:24 PM
mint's Avatar
2013 FIAT Abarth 500
Doubt you'll put a 9" wide wheel on the front with a 30mm offset without having to make fender modifications.
8.5" front, 9.5" rear is the standard for having the most safe specs without rolling fenders (not saying if you go with these widths you definitely won't need to roll, but usually people that go with these are pretty safe). Offset plays a big part in wheel fitment as well, so even if the wheel is 8.5" front with a lower offset, then you'll possibly need to roll at that point.
Old Mar 7, 2011 | 02:21 PM
Chappy's Avatar
AMG
I have 8.5" ET25 Front, 10" ET25 Rears....it's snug and my fenders are factory rolled. Running 235/40-18, 265/35-18 PS2s
Old May 13, 2011 | 11:51 PM
B-tsai's Avatar
CLK320, ML550, SL55, GL450
dlbehrns...
did these rims work out for you?
Using the calculator, it tells me that you would have 20mm less on the inside and 26mm more on the outside...
Chappy's setup should result in 1mm less on the inside and 25mm more on the outside....
So you were only 1mm further out on the outside.
Old May 14, 2011 | 12:31 AM
slowsky's Avatar
2011 C63
chappy, aren't those sl class et? so we can fit sl class et for the clks?
Old May 14, 2011 | 11:16 AM
dlbehrns's Avatar
99CLK320,
I bought a set of 17" X 8" Mandrus Millineums with a 32 offset all around and the fronts are flush with the wheel well and no fender roll. I don't think they will work without rolling the fender.
Old May 14, 2011 | 02:46 PM
Chappy's Avatar
AMG
Yes, they were made for the R129 SL73.
Old May 14, 2011 | 07:48 PM
GiZzO's Avatar
CLK55 / E350 Coupe
SL73!
You badass you
Nice to see your on Michelin PS2's, love those tires.
Old May 14, 2011 | 08:21 PM
Chappy's Avatar
AMG
Originally Posted by GiZzO
SL73!
You badass you
The 265s are TIGHT in the rear on these wheels. Next set I'm getting 255s.
