Lower Control Arm Fails-BOOM-Rust. Need tips on repair.
Old Mar 11, 2011 | 09:52 PM
Pancho's Avatar
2000 CLK430 Cabriolet
Have spent about an hour reading posts on the forum after doing a search for "control arm". Seems no one has had a catastrophic failure, but me.
Just came off the highway on commute home after a late night at the office. Hwy speed is 78 MPH for about 60 miles. Had been off the hwy about 8 minutes, stopped at a car wash bay, after wash, when pulling out of the bay at about 2 MPH, boom. See pics.
Looks like the rust gremlins struck again. I am surprised. My 19 year old Grand Cherokee, that has not been pampered like my CLK, has good A-frames. The CLK LCA's are made of thin pressed hollow steel structure. If this had failed on the hwy, I might not be here tapping on my keyboard.
Parts.com has LCA at $269 a side ($538). Ebay 4 Bilsteins at $300.
Have read enough about this that I am confused. Will do both fronts, and also new Bilsteins or KYB shocks, and ball joints.
Can anyone provide a How-To on replacing the LCAs, ball joints, and shocks?
Do new LCA come with the bushings ?
The fender is eff'd up. I, myself, replaced both fenders, hood, grill, bumper cover with new, last August, after a deer hit me. Good grief, but I love this car.
Attached Thumbnails Lower Control Arm Fails-BOOM-Rust.  Need tips on repair.-2011-03-09-clk-rust-lower-cntl-arm-broken.jpg   Lower Control Arm Fails-BOOM-Rust.  Need tips on repair.-2011-03-09-clk-rust-wheel-fender-2.jpg   Lower Control Arm Fails-BOOM-Rust.  Need tips on repair.-2011-03-09-clk-rust-hauler-truck.jpg   Lower Control Arm Fails-BOOM-Rust.  Need tips on repair.-2011-03-09-clk-rust-garage.jpg
Old Mar 12, 2011 | 01:59 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Dude that sucks!! I agree Ive never see a failure there Good thing you werent at speed but still looks like you tooka good %^!(** hit! I just swapped my LCA bushings for poly's and the tougest part was the springs and ball joints. With the right compressor the springs should be a snap. The ball joints are just a matter of applying pressure with a splitter and some good hard wacks with a BFH! That one hanging from your spindle may be an issue because you cant use the spring tension to help you seperate. Not sure if you have the adjustable bolts on the LCA, but if you do just make note of the orientation for reassembly till you get in for the alignment. I believe the new LCA's come fully assembled but if you want to upgrade the bushings to solid poly, use the w202 bushings... they are the same size. I couldnt find any listed for the w208
Old Mar 13, 2011 | 04:48 PM
Johnpidge's Avatar
W208 CLK55
Jesus - good job you we not still on the freeway - glad your ok - the bad side of this does not bear thinking about
Never ever seen one go like that before - weird no vibration or noises prior to it going????
Old Mar 15, 2011 | 11:40 PM
Pancho's Avatar
Hey guys, let me run something by you.
The vehicle is still in my garage, untouched. A couple of my friends have looked it over, and they seemed convinced that this should not have happened to a 10 year old car--any car--much less a Mercedes. I haven't found anyone that has had an A-Frame (LCA) member fail due to rust, on any car. One of my friends told me today that the more he thought about it, the more motivated he became, and he called MB Corp. (not dealership) customer service and told them about it, and they seem very interested and told him that I should call them. Another friend told me that this might be indicative of a failure that might start occurring more often, as these cars are getting older. This car spent the first 8 years of its life in Massachusetts--long winters, heavy snow & ice, with a lot of salting.
I keep all of my cars for a long, long time. Right now I have a 1993 Jeep Grand Cherokee; a 1997 BMW Z3 1.9; and my beloved year 2000 CLK, all of which I bought brand new. I've had a host of cars before this that I have owned the same way, and never, never, have I had this suspension (LCA/A-frame) member fail on any of them. I am beginning to think that this is a very dangerous MB/CLK problem that I should get more involved in, rather than just fixing the car.
Give me some feedback. I need some opinions on this.
Thanks.
PS. Here are some more photos.
Attached Thumbnails Lower Control Arm Fails-BOOM-Rust.  Need tips on repair.-clk-failed-lca-1.jpg   Lower Control Arm Fails-BOOM-Rust.  Need tips on repair.-clk-failed-lca-2.jpg   Lower Control Arm Fails-BOOM-Rust.  Need tips on repair.-clk-failed-lca-3.jpg
Old Mar 17, 2011 | 03:07 PM
bobbyjo9's Avatar
Thanks.
With the age of your car and lack of supporting similar failures, I think you will have a very uphill battle. If you have the time and patience go for it. For me I would rather replace and put behind me, as I doubt you will ever have this type of failure again.
Old Jan 9, 2013 | 02:22 PM
E55OhOh's Avatar
2000 E-55
Exclamation Same failure end of 2012
FWIW - I know this is like 2 years since last post,
but I just had the exact same failure on my 2000 E55. Rotted LCA which failed in the same location. I have a mechanic who previously worked at the local MB dealership for many years (northern Virginia area) and he showed me a drain hole on the bottom of the arm that gets plugged which exacerbates the problem. We looked at the left side LCA ands it was also plugged, but there was no evidence of rust. What we did find on both sides though was the first 3 inches of the bottom of the coil springs had snapped off from the rest of the spring. Hmm....
Old Jan 9, 2013 | 09:11 PM
Pancho's Avatar
Ditto that. Both springs on my car broke, just as per your description. I am preserving my parts, springs and LCAs, so that if these fail, and hurt someone, then I will offer my parts to that plaintiff so that they can be used as evidence in his case against MB. I have also preserved my emails, to and from MB, to show that they have been put on notice, and simply don't care. Save your parts. Put them in a box somewhere in your garage. Someday, some poor soul might have his MB LCAs fail at speed and get really hurt--him, his family, anybody. It would be a good way to help someone out. But make no mistake, MB does not care one iota about this dangerous problem.
Your left LCA could very well be rusted on the inside. You'll need some sort of arthroscopic probe to get into it and see. These LCAs are just pressed sheet metal, and MB metallurgy is shoddy, as evidence by 4 coil springs (yours and mine). Your LCA could very well be rusted on the inside. I replaced both. Imagine if your LCA had failed at 75 MPH. MB does not care.
