Tires rubbing on inner fender plastic
Old Mar 16, 2011 | 03:40 PM
NFSCLK's Avatar
RED CLK 430 Coupe
Has anyone ever heard of a problem with the inside fender plastic sagging and causeing the tire to start rubbing?
I have a rubbing issue on my passenger rear tire. Wheels are Mandruss Manheim 18 X 9.5 ET 35 should fit, right? I just had MB look at the alignment and they said it was in spec.
Mandruss rep told me he had a customer with a CLK55 with the same problem told me to use a heat gun and push back the fender plastic for more clearence.
What do you think?
Thanks in advance for your help.
Old Mar 16, 2011 | 04:42 PM
mint's Avatar
2013 FIAT Abarth 500
Yeah those should fit. When my car's up on the lift, the rears rub just a bit but when it's back on the ground, the negative camber fixes that. I'm on a 18x9.5 and ET35 as well.
What kind of camber are you running on the rears? I'm at -1.8 or something which I think is just barely in spec.
Old Mar 16, 2011 | 09:44 PM
NFSCLK's Avatar
RED CLK 430 Coupe
Camber
I took the car to the dealer for an alignment on Monday, I swear they didn't do anything to it.
When I asked they said it was out in the front and they adjusted it and the drivers side rear was also adjusted but not the side that was rubbing.
After looking at the reciept today I noticed there wasn't any charge for new bolts, I thought there would have been if they really did an alignment.
I explained to them I new the camber was off in the rear on both sides I could see it on the inside of the tires, wearing.
Old Mar 16, 2011 | 09:55 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
NO idea.. My car rubbed at the fender and i had to roll em since i got 15mm spacers.
but the negative camber will help lil bit.
