Does anyone has clk with brabus to show?
Here you go- Monoblock V Multipieces in 18"x8.5" front, 18"x9.5" rear. Lowered with H+R Sport springs. I love the rims, but I've had to buy 7 of them in the past 2 years, which has NOT been cheap.
The guy who's selling his Brembos has a nice looking 430 with the same rims- check out his thread.
Originally posted by Newbie
[B]Here you go- Monoblock V Multipieces in 18"x8.5" front, 18"x9.5" rear. Lowered with H+R Sport springs. I love the rims, but I've had to buy 7 of them in the past 2 years, which has NOT been cheap.
Yes, my front wheels rub the suspension at full lock.
And the fronts rub the tops of the inner wheel wells during hard cornering or on really big dips.
The uneven tire wear is a b!tch, and I've scraped the ***** out of TWO front fascias now.
You might consider putting in thinner spring pads and keeping your stock springs, just to cut the fender gap a little. Stock 430s definitely need to be lowered, but 1.5" with big rims is a little bit troublesome.
W212 E63, Audi R8 4.2, Panamera S, Range Rover Sport GT
What suspension setup are you running? And what tire size? Are you running the 235 and 265 setup? Those wheels shouldn't rub from my experience.
BTW your car looks great!!!!
can anybody tell me
1. where i can find the lowest price on 18" brabus mono v 1 pc set with tires for about 2000-2100 around Los Angeles/Orange county area ?
2. how much would the car drop when i go from stock spring pad 4(front) 3(rear) to 2(front) 1(rear) on clk430 ?
thanks, JJ
thanks, JJ
I love how everyone thinks that setup doesn't rub- I've had a lot of problems (for instance, the tires have rubbed through the wheel well rubber/plastic lining, and the tires wear VERY unevenly because of all the negative camber) and I'm well on my way to destroying my second front fascia.
