Answers - Hesitation, Stumble, won't accelerate, no power, misfires, etc... Fixed
Way to bump an old thread... but good info though.
If you haven't seen my troubleshooting thread yet, which has some similar symptoms and issues, I recommend taking a look, and everyone with a higer mileage car doing a good cleaning on the intake manifold. Just be careful of the vacuum line permanently attached to the bottom. There are also some fixes for that, but not easy.
https://mbworld.org/forums/clk-class...ough-idle.html
CHECK YOUR BATTERY
I had the same issue, I did Spark plugs, Ignition Wires, and Ignition Coils and still had the issue. It would hesitate if you tried to accelerate more than half throttle. I began to get frustrated, pulled the exhaust apart, checked the Cats and nothing was visibly wrong. ok so now let’s change the MAF maybe it is mechanical failing. Installed a new MAF, nothing. I proceeded to get an injector service. Nothing. A friend of mine then texts me after me and him going back and forth on the issue, “Did you check the battery?”. I then removed the battery from the car and installed an extra I happened to have around (what are the chances) plugged it in and fired the car up, took it up the road and could already feel a difference. I then proceeded to get up in the RPMs after the car had warmed up and I was on a larger road and I was shocked, The front end came up and it pulled me into the seat without skipping a beat.
'99ML430, '02ML500, '88 XJS, '00 CLK 430, 2 steam turbine generators, & 2 GE 7FA.01 gas turbines
Tell me Kenwood;
Is your navi cd in the head unit all the time, and if it is, do you hear it rattling about in there as soon as you open the door?
Also, tighten up your throttle cable adjustment to the point JUST BEFORE it begins to rev, warm it up, put in park and make sure you're still at idle rpm. Now go drive it like you stole it and get back to me.
E500 MercedesBenz
Answers
Thank you soo much for posting this. I have also had some of these issues. Hope I can find you again I have other issues pop up.
1. Bad Gas:
I opened the gas cap and took a whiff, all I could smell was VERY OLD gasoline, which smells like varnish. I filled a 5-gallon gas can, and added a bottle of fuel stabilizer. Poured that into the tank and gave it a few minutes to react. I restarted the car, and after it cleared the rest of that crap out of the fuel lines, it returned to “normal” where ran fine as long as it was under 3500rpm and 50% throttle.
2. Diagnostics and Sensors:
Up until this time, it did not trigger a CEL, finally the light came on. I ordered an ELM327 OBD-II adapter, and analyzed the trouble codes and the readings from all the sensors. The only codes it gave were Cylinder Misfire on 1, 2, 3, and 5; along with a Multiple Cylinder Misfire Code. All the sensors appeared to be functioning properly, and I did not see anything unusual. I posted graphs of the sensor data to see if anyone saw anything unusual, and I got no replies.
3. Catalytic Converters and Exhaust Backpressure:
I found a post on one of the MB forums, where a person who identified himself as an ASE Master Tech, described the EXACT set of symptoms that my car was having. He also got no replies. I emailed to ask if he found the cure, and he advised that both catalytic converters were plugged, and after replacing them the problem was solved. Please see his post:
http://mercedesforum.com/forum/gener...45/#post147505
So I removed the upstream O₂ sensors one at a time, and threaded in a pressure guage to check exhaust backpressure. I checked the backpressure first with the engine cold, and again with the cats at operating temperature, it was so low both times it barely registered on the guage. (Yes, I used a guage with a fine enough resolution to measure as low as 1-2 PSI)
4. Vacuum Lines:
I decided to take a closer look at the vacuum lines and valves, especially as they had linkage that connected to the manifold. (I did not suspect a vacuum leak because of the normal idle, the normal readings on the diagnostics, and the fact that no leak was indicated when testing with propane and solvent.) As I began carefully inspecting the lines, they looked fine. But when I flexed them they were full of cracks. Some of these cracks were all the way through the wall of the tube, but still were not apparent until the tube was flexed. Upon further inspection, I found a line that actually had a open hole in it, but it was on the backside where it was not visible.
(I should mention at this point that I live in the southwest, where it is VERY HOT and VERY DRY, both of which are bad for rubber, plastic, vinyl, leather, and other similar materials. The heat causes rubber to decay rapidly making it brittle and causing it to shrink. This car has repeatedly seen ambient Temps of 95 – 120 degrees F.)
These vacuum lines are used for the control of the variable intake system, which effectively changes the length of the intake runner, by opening and closing valves in the manifold. Since I had no vacuum going to this device (due to the hole in the line), the valves were stuck open all the time. I decided to replace every vacuum line on the engine. One line however attaches in a port on the bottom side of the manifold. This line sheared off flush with the bottom of the manifold when I touched it, making it impossible to remove with the manifold on the car. The tube connects to a port that is actually recessed a couple of inches back into the manifold. In order to repair and replace the line, I had to remove the manifold.
5. Removing the Manifold:
Upon removing the manifold, I discovered that both the intake runners, the intake ports, and the intake valves were all coated with sand. (While cleaning my shorts, I began contemplating the logistics of selling it piece by piece on eBay.) Because the manifold is not supposed to be serviceable, I decided it would be best to order a new one. I happened to find one on eBay that night for $300 with a guarantee, so I ordered it. Then I decided to split my manifold open and take a look at it (seeing the inside of the manifold and how it was designed, I started to realize the bad vac lines were probably the source of my problem). Indeed, it was full of sand.
All the black stuff in the photo is sand covered in gas/oil...
Attachment 382028
6. Removing the Sand:
I was lucky and only 2 cylinders had open intake valves. I spent an entire afternoon carefully cleaning the ports and valves with solvent and paper-towels. I adapted a wet-vac down to a clear, 1/4” line that I could insert into the port to remove sand and solvent during this process. I carefully wiped the walls of the ports with a paper-towel soaked in solvent. Then I sprayed the walls and the valves with B-12 Chemtool, while suctioning at the bottom of the port.
On the cylinders that had open intake valves, I removed a spark plug, and inserted the suction line into the cylinder. I did the same as on the other cylinders, but flushed the port with only small amounts of solvent, with the suction on to instantly remove the fluid/sand from the cylinder. The clear tubing allowed me to make sure that I was removing about the same volume of fluid as I was spraying in.
7. Spark Plugs:
While I had the engine partially disassembled, I decided to replace the spark plugs. They were coated with the same oily, sandy deposits that the ports were, so this turned out to be a good idea. When I was removing the coil packs, in order to access the plugs, I noticed that one of the plug-wires on cylinder 7 was not fully seated on the coil pack. The contacts were not in contact, and so it had been arcing creating a buildup of ashy deposits on both contacts, and also apparently creating a fair amount of heat as the plastic housing around the contact on the coil itself was distorted and cracked. The crack is only in the plastic around the contact, and not in the housing around the coil, and does not appear to affect the functionality of the coil. So I carefully filed down the deposits on both contacts until I had exposed bare metal.
8. Intake Gaskets:
I took a little time to clean up the new manifold as best as I could, again shooting solvent through the runners, and suctioning out what I could. I installed the throttle valve using a new O-ring, and then I installed the new manifold, and finished reassembling everything. During reassembly, I replaced all the rubber seals between the throttle actuator and the air filter housing. Again, the heat had caused all these seals to shrink and harden, leaving a gap for air to sneak by, bypassing the air filters, and in the case of the lower seals, also bypassing the MAF. This was probably the main cause of sand getting sucked into the motor.
9. Fuel Filter:
Upon restart, it ran much better but still had a stumble. The next day I filled up with gas, and added a good fuel system cleaner. As the solvent did it's work, it started running a little rough and started to throw misfire codes again for a short period, followed by triggering the CEL with no codes, and then returned pretty much to normal. The engine could rev all the way to redline again. But if I got above about 70% throttle, it would hesitate, although not nearly as bad as before. I hooked up the diagnostics and floored it and looked at all the sensor readings. Everything was okay except that the O₂ sensors were indicating a lean condition. I suspected fuel pressure, so I waited until I had used up all the gas with the fuel system solvent in it, and then replaced the filter.
10. Voila!
The car is back 100% back to normal with full power. And it runs smoother than it ever has since I've owned it.
A diagram of how the variable intake works:
Attachment 382029
The black stuff in all these photos is sand covered with gas/oil...
This is the lower portion of the manifold, you can see the valves that control the variable intake. When they are open air enters through the valve, bypassing most of the length of the runner. The valley running down the middle is actually the top of a tank which acts as a vacuum reservoir.
Attachment 382028
This is the upper portion, or top, of the manifold. The ports down the center are where air enters when the valves are closed.
Attachment 382031
Here are some shots of the ports, you can see the buildup of sand on the walls and valves.
Attachment 382032
Attachment 382033
Attachment 382034
Here is one of the ports after cleaning:
Attachment 382035
A couple shots of the motor with the intake off:
Attachment 382036
Attachment 382037
This is me when I realized there was sand in the motor...
4. Vacuum Lines:
Attachment 382028
7. Spark Plugs:
8. Intake Gaskets:
9. Fuel Filter:
10. Voila!
Attachment 382029
Attachment 382028
Attachment 382031
Attachment 382032
Attachment 382033
Attachment 382034
Attachment 382035
Attachment 382036
Attachment 382037
Problems with intake manifold hesitation when excelerating
I live in the desert as well and ive just had everything done that you describe. First it coded spark plugs and ignition wiring i had all of them replaced then it was the plastic lever on the intake manifold my mechanic carefully took it out of car and cleaned it and attached metal lever i ordered. Then put everything back together then the maf coded i had that replaced thought this ordeal was over then cel came on i knew the ambient sensor needed replacing but didnt think it was that big a deal cuz cant find it on front of car. So car was doing a little hesitation when accelerating and then it would take off fast. So i had codes ran again and discovered hose had come off thermador system. Put hose back on and cleared codes but its still doing the shudder ot lull when accelerating. And when going the speed limit she want more almost like shes gunna stall if i dont go faster. She is a 2008 mbz clk350 with about 157k miles on her. Im thinking sand got in when the thermador wasnt connected. What do you think?
This is when my mechanic took out the intake manifold to put lever on. Its been nothing but problems since.
