Spacer Problem
Old Apr 14, 2011 | 05:45 AM
MG21's Avatar
99clk cabriolet, 2014 E350, 2020 C63S
Spacer Problem
Just installed some 5mm H&R spacers on the rear of my 99 cabriolet.I run 19X9.5 HRE wheels in the back. Bought exactly what the site told me to get and got 35mm extended bolts. When the tires spin there is a clicking noise now. What is the problem?? Any help is appreciated.
Old Apr 14, 2011 | 11:28 AM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
its rubbing. Roll the fender.
If its not it, make sure FIRST the bolt is not too long.
It happened to mine but i got 19x8.5 and 15mm spacer.(had to roll my fender)
make sure u get a wheel lock so they dont steal your rims
Old Apr 14, 2011 | 12:24 PM
mint's Avatar
2013 FIAT Abarth 500
Mr. Mike's second diagnosis is correct. If it was the tire rubbing the fender, it'd make a different sound than clicking.
Definitely, your bolts are too long in the rear and hitting the ebrake. Don't let this go on too long or you'll need to replace the ebrake parts. 28mm is supposedly the standard length for aftermarket wheels, so adding 28mm + 5mm spacer = 33mm bolt. Either grind them down a few mm or get shorter ones. RADUSAdirect.com has 29.5mm and 34mm. Obviously, if you get the 34mm you'll need to grind those down as well so personally, I'd just get the 29.5mm and not have to grind them down and call it a day. Phil @ RADUSA is a good guy to work with and hands down, RAD's bolts are the best in the industry.
Old Apr 14, 2011 | 12:37 PM
sonnyhoang's Avatar
w208 CLK430, w212 E350, w221 S550
I had the same problem as you when I used a 5mm spacer so I just grabbed a 10mm and and my wheels became more flush. I then realized that the lugs were too long too. Goodluck n post up pics!
Old Apr 14, 2011 | 01:02 PM
that is where i got my lug nuts and wheel lock from radusa. I called em and told em what i had and tire size and my spacer.
good luck
Old Apr 14, 2011 | 05:34 PM
MG21's Avatar
Thanks for the responses. Wheels are definately not rubbing. I'll try some shorter bolts. The site i ordered from only had 35 mm. Thanks.
Old Apr 14, 2011 | 05:51 PM
dlbehrns's Avatar
99CLK320,
pull the bolts off and look end of each to see which bolt is hitting. grind the one that are and don't worry about the rest.
Old Apr 14, 2011 | 07:25 PM
jbenz2001's Avatar
2001 clk 320
i told u mg21 lol.
Old Apr 14, 2011 | 08:13 PM
Opal_CLK's Avatar
2000 CLK 320
yes everyone is correct. had the same problem with mine. studs were too long, had to grind them down a bit
Old Apr 20, 2011 | 03:51 AM
MG21's Avatar
Went with a 10mm spacer instead and fixed the problem. Thanks everyone for the info.
Old Apr 20, 2011 | 06:18 AM
moreno73's Avatar
02 clk55 amg cabrio
I had the same problem, I bought 19" rims w/ offsets of 30mm in front and 35mm in the rear I called h&r and they wanted to know my hub height so they could send me the right spacers and lugbolts!
