Bolts, when replacing lower control arms, what's the story ?
Replacing the original LCA's with new, stock. What is this about replacing the bolts on the LCA's ? Seems I am not supposed to use the original bolts, but instead replace them with new camber bolts. Why can't I use the take off bolts on the new LCA ? I don't get it. Can someone clear this up ?
No lowering, or any mods.
Replacing stock front lousy failed MB LCA w/ aftermarket,
so will stay w/ same un-cambered bolts.
Just to be clear on rear,
do you need the adjustable camber arms on rear, when just replacing to stock ?
Again, thanks.
No you don't need adjustable rear arms if you're at stock height, as your camber is preset from the factory using the non-adjustable arms supplied. Most people with extreme drops require these to maintain decent tire wear or tweak settings on the track but as I'm guessing neither apply to you, just get the OEM camber struts.
Thanks for the info, but, What do you mean by, "struts" ?
So my advise is get your alignment checked when you fit the new arms.
Good luck
Damn terminology.
Good luck
