AC problem: Takes a while to blow cold
So I've been reading a lot of the AC threads lately and I can't seem to figure out what is going on. I "think" I just need to add some R134 to the system, and I haven't run the codes just yet, but I just wanted to see if any of you have had this problem as well; here's the issue:
When I start my car whether it be in the morning, first thing, or throughout the day, the AC starts off my blowing (not really warm) but semi-cool air.
After driving the car around for say...20 min, it then begins to blow ice cold. This is a consistent problem, and has been doing it for about 3-4 weeks. Every time, it just takes forever to really get cold.
Could it be that the compressor is going out? Or am I right with needing to add some R134? I know I need to pull the codes, and I'll do so when I get home tonight to the car.
Thanks very much for any help, guys.
I ran the built-in diagnostic that displays codes on the panel (hold down REST for a few seconds) and the freon pressure indicated a range from 7-10, mostly hovering around 7-8. I've never had R134 added and have no idea if the one previous owner did.
How tricky is it to replace the R134 ourselves?
Recharging R134 isn't too hard from what I've read. Do a search and you'll find the answer.
