Front wheel alignment advice please?
I got the car aligned after fitting the bolts and the readings showed that my cambers were alot better then before fitting the camber bolts but still just outside the recommended max negative camber setting. However despite this I am now getting outer tyre edge wear as if the cambers are too positive despite the readings. Could this be down to too much toe-in do you think?.
Does anyone know a really good alignment place in Glasgow UK? I used Performance Tyres before at Anniesland. Thanks
PS The car drives and feels fine.
