Will these rims fit?
Old Jul 19, 2011 | 07:53 PM
fredyfunk's Avatar
CLK 55 AMG
http://cgi.ebay.com/ebaymotors/Merce...ht_4346wt_1169
It shows the offsets for the front as 30 and the rears are 31
Old Jul 19, 2011 | 11:10 PM
s0urce's Avatar
1999 CLK430
Which rims do you currently have on your car?
Old Jul 20, 2011 | 01:34 AM
fredyfunk's Avatar
CLK 55 AMG
I believe they are the monoblocks. However, I don't know the offsets and I don't know if these offsets will fit on our CLK.
So if anyone could chime it, I'd greatly appreciate it. TIA
Old Jul 21, 2011 | 10:05 PM
fredyfunk's Avatar
CLK 55 AMG
anyone? Fronts are ET +30 and Rears are ET +31. Rims are 19in and 8.5/9.5.
I just wanna know if they would fit on the CLK but I have no idea because I've never bought rims before. From what I can tell from reading other posts, I'm thinking that spacers are most likely going to be needed buy any help would be greatly appreciated.
Old Jul 22, 2011 | 01:46 PM
dlbehrns's Avatar
99CLK320,
30mm offset pushes the rim further out from the original 35mm. If you add spaces you would push them out even farther so I would think that would not be a good idea. I purchased a matched set 17" x 8" wide by 32mm offset. the front is perfectly flush with the wheel well. The rear not quite so. From what you have posted I think the front "may" be slightly outside the wheel well given they are 8.5 wide. I don't think the front will work but could be wrong. I would call tirerack.com or discounttire.com for some technical advice. There are tire calculators out there too http://www.1010tires.com/wheeloffsetcalculator.asp
I just noticed that you have a 55 which has bigger brake calipers which can throw a wrench in the works. Call those two sellers for advice.
