suspension experts
Old Jul 24, 2011 | 04:08 AM
VIPclk320's Avatar
CLK W208
suspension experts
hey everyone, I've been having this swerving issue that in the freeway the car feels like it pulls side to side, its not super bad but ad enough to notice, also it feels like it moves a bit heavy like as if the brakes were on half way. This is the list of what i have done so far:
Complete new oem drag link and outter tierods
OEM Stearing damper
poly lower control arm bushings
lower ball joints
new tires
alignment
new rotors and pads
after changing the bushings and the drag link my stearing improved significantly but the heavy driving feel and the floating/swerving is still there.
could this be wheel related issue because when i purchased my new wheels the holes had to be drilled a little but they put sleeves in them and i purchased the proper conical lug bolts as well as hub rings.
also if someone can let me know how often i should change my springs and spring pads as i have had my H&R springs on my car for 7 years but the shocks are new.
Old Jul 24, 2011 | 10:55 AM
dlbehrns's Avatar
99CLK320,
Hey Ash, you are the man when it comes to the w208. Sounds like you've done your homework. Do you have a different set of wheels & tires or an oem set to run for a test?
Old Jul 24, 2011 | 02:02 PM
VIPclk320's Avatar
CLK W208
whatsup Dave, I havent tried that yet because i had the tires checked and the wheels checked and rebalanced and everything checks out perfect and i really dont think the swerving issue would be because of the wheels, but again you never know.
Old Jul 24, 2011 | 03:08 PM
Williams707's Avatar
2000 CLK 320
Car Issues....You still going to be able to pick me up on Friday?
tery's Avatar
CLK320
I think it might be the corner weight balance is off , maybe try a shop that can check each wight of each corner.
Old Jul 24, 2011 | 07:17 PM
dlbehrns's Avatar
99CLK320,
OEM Stearing damper
lower ball joints
new tires
alignment
new rotors and pads
Hey Ash, I forgot to share with you the latest, which I might add is original material: I was working in my garden the other day and I was bitten by a garter snake. They are a non-venemous snake. The only ramifications are that now I'm suffering from Reptile Disfunction.
No copyrite. Feel free......... I crack me up!
Old Jul 24, 2011 | 07:55 PM
VIPclk320's Avatar
CLK W208
Tery can you elaborate on that, i'm not sure what you are referring to but it sounds like something that would cause my issue.
LOL i havent gotten any funny k=jockes or sonds from you lately but this was good.
William707, Yes sir brother, i will pick you up at LAX on friday, I'll check the flight number friday morning for any early arrivals or delays.
Old Jul 24, 2011 | 08:38 PM
tery's Avatar
CLK320
It might be one of your spring is sinking or when installation of new shocks the spring did not seat in the right place, causing one corner higher off the ground just by a bit . Thats my guess if we assume that everything is all check out fine. I think this might be the issue.
Old Jul 24, 2011 | 09:22 PM
dlbehrns's Avatar
99CLK320,
tery, still racing your Benz?
Old Jul 24, 2011 | 10:02 PM
tery's Avatar
CLK320
Not this year, car is sitting on jacks now , trying to find what I can take off make it more light wight .
Old Jul 24, 2011 | 11:46 PM
VIPclk320's Avatar
CLK W208
Thanks tery i will check that, can you also tell me what is the typical life span of H&R springs, Ive had mine on since 2003.
Old Jul 25, 2011 | 11:58 PM
GiZzO's Avatar
CLK55 / E350 Coupe
Quality aftermarket springs should out live the car.
Defects, rust, structural damage, would be the factor if your springs are sagging..never heard of springs simply wearing out.
If the case you'll see the car sagging to one side.
