subframe bushing
Old Aug 2, 2011 | 09:34 PM
VIPclk320's Avatar
CLK W208
subframe bushing
anyone with any experience with the rear subframe bushings. is it easy to change or how its done. thanks.
Old Aug 2, 2011 | 09:47 PM
Ruination Fan's Avatar
02 CLK430
You need to lower the rear subframe down and press out/in the bushings with the proper tool. I have only done it a couple times, and lowered the subframe both times to have easy access to pressing in/out the bushings.
Old Aug 3, 2011 | 12:03 AM
VIPclk320's Avatar
CLK W208
how many bushings are there?
Old Aug 3, 2011 | 12:09 AM
02 CLK430
2 front and 2 rear(one on each corner)....unless u also count the bushings for the diff (another two bushings).
Old Aug 3, 2011 | 01:56 AM
VIPclk320's Avatar
CLK W208
cool brother thank you. now how hard is it to drop the subframe, or do i just have to lower it? do i have to take anything off to lower the subframe?
Old Aug 3, 2011 | 10:16 AM
02 CLK430
From off the top of my head you need to: disconnect driveshaft from the diff. Unbolt the calipers from the hub and support them. Unbolt sway bar from the endlinks. Unbolt the shock at the a-arm. And I think Unbolt the speed sensors from the hub. I recommend getting it out so you have plenty of room to work.
Old Aug 3, 2011 | 03:39 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
if you dont have the press tool you can use fire. just be carefull.
