Instructional: Install Motor Mounts
I was VERY glad that I purchased some ratcheting open-end wrenches for the top bolts. It would have taken a lot longer without them.
Mike
2002 CLK430 Cabriolet
Great write-up from what I can tell. But when I click on the pictures that Pancho posted, nothing happens. I can only see the thumbnails.
Does anyone know how I could see the pictures (with the write-up)?
Thank you!
Hans
Up until this point I followed the write up, had the car in the air on jack stands, etc. I had plenty of room for the mounts to come out underneath without doing anything extra.
Here’s an alternative to using the factory MB jack if you prefer. A 5/8” x 8” stud fits inside the factory jacking point. I assume you could also use a grade 8 bolt. Just be aware of the jack placement if you’re going to put the car on jack stands. And no....my car is normally not this dirty but it's winter here.
Squeeze hands between those two hoses
Once I got the car jacked up, I was able to do everything else from underneath without having to disconnect or move anything (lucky me)! Found the driver's side to be less difficult, as the mount had enough room to come out. Passenger side was a little more difficult with the exhaust manifold in the way- just had to jack the engine up a little higher for more wiggle room.
I'm very happy with the ride quality and can't wait to drive again.
Out with the old! I used W209 motor mounts.
Tools of the trade: The tiny 16mm and ratcheting 5/8 were life savers with the upper mounts- with a little leverage from a ratchet.
