Roof locks out on opening
Any help is appreciated
You can test the pump by putting the rear head rests up and down with the switch on the dash. If they do go up and down, then the pump and the hydraulics are probably okay.
When you manually reset the roof, do you follow this procedure? If not that would explain why it's so hard to assist the roof back.
If the roof closes without any problem then I think all your solenoids are okay.
I had what sounds like a similar fault and was greatly helped by Klaus from TopHydraulics and Serendipity >>>> https://mbworld.org/forums/clk-class...p-problem.html
