DEAD BATTERY
Old Jun 2, 2012 | 09:34 PM
JONNT's Avatar
1999 clk320
DEAD BATTERY
HOW DO YOU JUMP START A 1999 CLK320 FROM UNDER THE HOOD SINCE I CANNOT OPEN THE TRUNK WHERE THE BATTERY IS, THANKS
Old Jun 3, 2012 | 12:00 AM
Birdseye's Avatar
2013 C63 P31 Eurocharged, 2006 SLK55 R171, 2013 Audi RS5
The trunk should open with the silver "manual" key that hides in the main electronic key. Have you tried opening the trunk with that?
Old Jun 3, 2012 | 08:59 AM
tomtomtomtom's Avatar
02clk55///2010GLK350
There is a jumper post in the engine compartment...drivers side...you'll see a small black box w/ a + on it.
Check owners manual for picture
Old Jun 3, 2012 | 08:15 PM
Pancho's Avatar
2000 CLK430 Cabriolet
If you have a battery charge, connect to positive lead to the post under the x box under the hood near the driver side fuse box. Connect the neg lead to any other metal. Let the vehicle charge for about a half hour or so, then then you can use the trunk opening button on the console, or the key FOB button, to open the trunk, then connect the charger directly to the battery posts.
Sometimes, if your battery is not too low, you can get the buttons to work immediately upon connecting the battery charger.
Also, if you have a booster pack, then it will also get your buttons working quickly.
