Convertible Top Removal
Old Sep 25, 2008 | 02:27 PM
Silverbillet's Avatar
2001 CLK430 Cab; 2008 GL550
Does anyone know how or have instructions on how to reomve the canvas off the frame of the convertible top? There is a wire in the top that snapped and want to replace it but no idea how to remove the canvas. Thanks ahead guys.
Old Sep 28, 2008 | 09:44 AM
CLK430Jim's Avatar
2000 CLK430 Cab silver/black/ash
This thread may help with your problem: http://www.benzworld.org/forums/w208...g-problem.html
Old Sep 30, 2008 | 02:11 AM
Thanks, you're right on the money. Thanks again.
Old Sep 30, 2008 | 08:19 AM
CLK430Jim's Avatar
Do make sure to replace both sides (cables).
Old Oct 1, 2008 | 02:13 PM
Do you know what these cables are called or have the part number?
Old Oct 1, 2008 | 02:17 PM
sick430's Avatar
CLK Cabrio
yeah i need to replace mine as well. please take lots of photos when you are replacing your cables.
thanks
Old Oct 2, 2008 | 05:14 PM
CLK430Jim's Avatar
In response to your questions concerning CLK top operation, there are two cables attached to the convertible top header plate and running towards the cross bar forward of the rear window. Mercedes refers to these cables as shocks ( part #A2087701865). The cables are attached at front of top. To access, remove the vinyl panel inside of the header panel. First, remove the three millimeter internal hex that attaches the top handle. Then, remove two screws at each end of vinyl panel. Once the panel is removed, you can remove the forward end of the cable with a ten mm socket. The rear of the cable where the break has occurred has a push in plastic retainer that must be pushed rearward through the black metal crossbar. Once removed, the retainer will split in the middle allowing the new cable to be fitted within. Note: The cable must be routed through the crossbar prior to being fitted inside the retainer.
Hope this helps
copied from Mercedes Forum
Old Oct 2, 2008 | 07:09 PM
Thanks for the part number Jim.
Old Apr 20, 2010 | 12:44 PM
jaysoncallan's Avatar
clk430
I know this thread is a little old but I have the same problem with my top and was wondering if one of these cables breaking would have any connection to the top to stop operating? My top will not go down any more but the headrests in the rear are operational.
Old May 4, 2010 | 06:28 AM
lowe712131's Avatar
2004 CLK55 AMG
Hi - don't know if it helps, but when my roof stopped working, it was as simple as the metal roof cover (horizontal part that hinges up to stow roof away) not being latched. Gave it a bit of a tap with hand, it latched down and everything back to normal! The controller looks for several things to be in place - i.e. trunk is closed, roof cover in boot in place etc.. before the opening or closing sequence can begin. If one (or more!) isn't in place, the button blinks at you and it won't work. At least if your headrests work, it isn't the hydraulics. Hope this helps. Cheers
Old Jun 29, 2010 | 10:14 PM
mattkay's Avatar
CLK 320 Convertible
Cable instructions ok but how to put back the top handle
Hi, I had the same problem and yes it was the two cables that
snapped off the rear (the middle cross bar just behind the rear window).
I removed the front vinyl to expose so I could put them back
in place (using the plastic retainer as instructed)
But now I cannot reinstall the top handle at the front.
If I install the vinyl/plastic cover first then I cannot turn
the handle in position to insert and screw in the handle
(and it needs to turn because the plastic is not letting it
in at its straight position).
So I am trying push it up so that it turns enough to insert
the screw bar but it cannot be done. Is there some trick
to make this easier?
If you have tried it hopefully you understand what i am talking about...
thanks for help!
Old Jun 29, 2010 | 11:10 PM
mattkay's Avatar
CLK 320 Convertible
Ok now
Ok problem in above post solved. I was afraid to push
the handle a lot but I finally did and got it to turn.
Old Jun 27, 2011 | 07:24 AM
gcodin's Avatar
w202
No pictures anyone?
Old Jun 4, 2012 | 08:55 PM
msorrells's Avatar
Here's a great step-by-step with pics:
http://forums.mercedesclub.org.uk/sh...ad.php?t=86053
I found the best prices on the cables (or shocks) here:
http://www.trademotion.com/parts/ind...icleid=1419667
(Don't worry about the description of "Folding Top". It is the right part.
