Need help ID'ing fuse wire colors for brake light ?
Old Jun 23, 2012 | 02:55 AM
Pancho's Avatar
2000 CLK430 Cabriolet
Problem:
I have a bad fuse holder. The Brake Lamp fuse in fuse #2 in the interior fuse block at the left end of the dash. The #2 fuse holder does not provide a good bite on the fuse. I will get the typical brake switch multiple error prompts, and at the next red light, I turn off the engine, open the door, pull off the fuse panel cover, and quickly pull out and reinstall the #2 fuse. When I restart the engine, the codes are gone. It is annoying. Have been doing this for years.
Remedy:
As a remedy, I would like to patch in a single in-line fuse holder, but I need to be able to identify the two wires that come from the #2 fuse holder.
I would like to know what are the color codes for the 2 wires that come from the #2 fuse holder. Has anyone a schematic that can provide this info?
