W208 (Cab)Windows Roll down by themselves.
I am having a very unusual problem with my 1999 CLK 230K Cab. When im driving on an uneven or rough road or i go over a speed bump too fast or hit a pot hole or go around a corner to the right at more than 30MPH all 4 windows roll down at the same time and the convertible light flashes....
Please help me resolve this.....has anyone else experienced this and have solution? where and what to check.
STEP 1: Open Convertible Top.
STEP 2: Remove the suns visors on both sides of the vehicle.(6 screws total)
STEP 3: Remove overhead Panel.
STEP 4: Remove the overhead lighting cluster mounted by (4 screws).Tho NOT NECESSARY)
STEP 5: Check the Limit Switch and its mount for any play. (Mine was wobbly loose which explains why windows were rolling down every minute when driving.) Which kept the roof engaging and disengaging. Now i'm able to speed on any surface, go around any corner and enjoy my the cold air.
I have attached 3 pictures for some perspective. It is not a "bad sam" as REDWAMG mentioned and now i am able to enjoy my A/C. lol
Hope yours is this simple.
I had the same problem for months. Your fix solved my problem. The 3 bolts holding that switch were very loose. Hitting a bump or even turning a corner would move the switch, causing the switch activation lever to contact the convertible top latch, causing the "convertible top automatic window roll down" to activate. Tightening those bolts did the job.
Thanks again!
Thanks again!
Convertible top latch must be hitting the activation lever causing the contact to begin the top down process. I believe the windshield frame must be torquing some what causing the latch to make contact - thus telling me the latch must not securely latched down tight...
Any answers or experience with this problem...
Thanks ahead of time,
Ken
Ken
Loosen all 3 bolts and use hand pressure to push the module skyward/rearward as you retighten the bolts. If that doesn't completely solve the issue, then remove all 3 bolts and install a single washer on the single forward most bolt and retighten. That should move thew contact point closer to make a more secure connection.
I have checked for the loose micro switch mount, mine was tight. I did remove the bolts and put a washer between the front hole and the windshield top frame. I removed the soft top compartment in the trunk which has a micro switch on the passenger side. I thought if the micro switch was not engaged, the windows would not go down when the call for opening up soft top was initiated by the soft top switch on the console. My soft top doesn't work with the console switch anyway. I think the pump is fried.
I tested the front micro switch before reinstalling and found that when I probed the brown and gray wires there was continuity whether the switch was open or closed. This confused me. I cut the brown wire and found that when I had the probe on the brown wire at the switch and probed the gray wire that I only had continuity when the switch was pulled back, I'm guessing this is what happens when the soft top is latched to the top of the windshield. The cut brown end of the wire away from the switch, as well as the gray wire that wasn't cut, showed continuity to the ground of the body. So, I put everything back together and thought that I'd ask for help.
I could really use some help ... please
What do you think of this approach and where would a good place to break the circuit be?
Wait a second, wouldn't the circuit for the automatic roll down feature when lowering the soft top be separate from the window switches on the console?
This thread is old but the repairs are valid.
Try getting as much information as you can and make a new post. dont cut any wires on these cars.
I knew where it belonged. This guide or post (not sure what it's called) screws into the soft top bracket on the outside of the latching claw. It had somehow come unscrewed and was resting into the hole of the mount above the windshield. The passenger side guide was missing altogether. I was able to make one out of a bolt, a nut, and a piece of plastic. The one on the left is the fabricated one.
I installed them with washers, but maybe Loctite would be a better choice.
