How remove fuse panel/light switch ?
Old Aug 5, 2012 | 06:23 PM
Pancho's Avatar
2000 CLK430 Cabriolet
How remove fuse panel/head light switch ?
This is about the fuse panel at the driver's end of the dash (in cabin).
The fuse perch for the brake light switch is jammed--won't accept the blade fuse. Perch is damaged, so it throws the typical fault codes for the brake light switch, and I lose my brake lights, ABS, etc.
Need to get at that fuse perch from the back. Looks like fuse panel is part of the head light switch assembly.
How do I get this fuse panel/head light switch out, so that I can work on the fuse perch?
Diagrams, schematics, instructions, anything.
Thanks.
