Akebono brake pad EUR853 from APW
Old Aug 31, 2012 | 04:11 PM
J56BP's Avatar
2002 CLK 430
HEY all
installed front/only pads today. took it for test drive, 1st push brake very soft, 2nd push/pump & then is perfect...& then again 1st pump soft 2nd hard etc......WTF (was hard b4 but so much noise, had ebc).
no leak or sound/noise what so ever. btw i took the cap off the fluid tank. so i can push back piston.
plz any advise
Now I hear hissing air flow sound when step on brake pedal. Its coming from right above brake pedal inside cabin.
Was not there b4.
Old Aug 31, 2012 | 06:29 PM
J56BP's Avatar
2002 CLK 430
Really.......plz. lol
Old Aug 31, 2012 | 09:30 PM
MarcusF's Avatar
2002 CLK430
What you’re describing sounds like spongy brakes. The fluid is supposed to be changed every two years. If it's been longer than two years, the simple answer is a flush is probably due. The longer answer is here.
Old Sep 1, 2012 | 04:45 AM
J56BP's Avatar
2002 CLK 430
What about the hissing air sound when pushing brake pedal? Btw fluid was never changed.
Ty Marcus
Old Sep 1, 2012 | 08:39 AM
rsparso's Avatar
02 CLK 55AMG
It sounds like your brakes need bleeding at the least. The hissing is quite possibly the brake booster, you're hearing it more because of the longer pedal stroke due to air in the lines.
Old Sep 1, 2012 | 09:05 AM
J56BP's Avatar
2002 CLK 430
called my local thiefbranch (MB of pembroke pines) flushing brake service $149.99 + tax.
what if it won't corrrect my issue & i mean is something alse wrong? then $149.99 is a donation
Old Sep 1, 2012 | 09:45 AM
rsparso's Avatar
02 CLK 55AMG
Do it yourself then.
I'd still vote that bleeding the brakes is the first thing to try, that'll kill two birds with one stone
Old Sep 1, 2012 | 02:04 PM
jserio's Avatar
2004 CLK500 Cab
I second bleeding the brakes first. Getting an extra person to pump the brakes and you get in a wheel well won't cost anything. Bleed and see if problem still exsists. If not then get that fluid flushed. The car should brake as if it were new.
Old Sep 1, 2012 | 04:47 PM
J56BP's Avatar
2002 CLK 430
here we go
i went to my local part store got a loan vacuum hand pump. also 1 liter brake fluid. i pump the ***** out ea line ......so much air like its hooked up to oxigen tank. wtf i only installed pads. i have no clue what happend.
anyways i got it better but still soft @ 1st push on brake pedal. still have the hissing air flow sound tho when pushing brake pedal.
next week will do the 2 person method with my son.
plz if any advice let me know.
ty for all the help so far.
Old Sep 2, 2012 | 11:32 AM
rsparso's Avatar
02 CLK 55AMG
Some systems can take an age to bleed. The last car I had was a 6L GTO, that system really didn't "like" vacuum bleeders. Try the conventional way. If you can't get clear steady fluid from each caliper it might be possible there's a tiny air leak. You made sure you never stressed the lines when you changed the pads ?
Somethings sounds as though it's just gone wrong since the pad change.
