front end play/Hey DIYers
99CLK320,
I can feel my car moving slightly left or right on crummy uneven road surfaces. with the left or right front wheel off the ground, with my hands pullng back and forth at 9 and 3 oclock I am feeling a slight bit of play and can actually hear it as well. I don't notice it as much with 7" rims as I do with 8". I only have 37K on the car. hate to be so **** but......has anyone experienced this with low miles. what could it possibly be with that low mileage?
Yes. Check for the following:
Tie-rods. Check by (in the air) grabbing the tire and wiggle left to right (horizontal). Should be 0 play.
Hub or bearing. Check by (in the air) grabbing the tire on the top and bottom, wiggle vertically. Should be 0 play.
02 clk 55, 13 GL 450
There could be a cheaper easy solution. Your at the mileage the steering stabilizer is probably toast. It's sole "purpose" is to counteract the wheel being jerked by uneven surfaces and impacts to either wheel. look for leaks here or just remove one bolt and feel for resistance in the shock. If you can compress/expand easily, then Id start there.
99CLK320,
bobby, I have one from autohausaz sitting on the shelf I got on sale. plan on it when I change out to the winter tires. i'm thinking that the miles are too low for that other stuff to be going out. I drive and corner agressively and have tracked the car on a road coarse only once but don't think those parts should be worn yet. maybe. will try to remember to post back when its done.
Yeah.. I'd roll with the easy stuff first and it doesnt get any easier than the stabilizer. You can easily check the other parts when you have it jacked up. The ball joints are a weak link too, but you should be hearing them clunk and wear tires if they are bad. They seem to have a short life also but 37k is a VERY short life
Is this the stabilizer piece you are replacing? I think I may also need a new one. I shimmy a little to the left and right on ****ty roads...not feeling it...feels like the front end has too much play
![](http://img837.imageshack.us/img837/4829/w01331717040lem.jpg)
99CLK320,
No. I think that is called the drag link/center link. There is a little shock absorber/steering damper that connects to that piece that took all of 5 minutes to replace and it cured my problem. http://www.autohausaz.com/search/pro...id=26@Steering System&gid=7412@Steering Damper
99CLK320,
that link does not work. . go to www.autohausaz.com and search Makes > 2002 Mercedes > CLK430 > Steering System > Steering Damper
