How much mod to fit these tires???
BUT, if one opts for the 245 & 275 setup... how much modification will I need?
Ben and dronellis, you two have this setup, correct? How much work did it need? And was your setup 245/35 & 275/30 OR... 245/40 & 275/35???
Thanks,
Danny
MMGRAD, I would refer you to A1 Autobody to do the work. The feel of 245/275 vs 235/265 is definitely worth it, but be prepared for a lot of work to make it fit.
I had 275/35 set up on my 320, and there wasn't any rubbing problems with the fenders rolled. I was using nitto's too, which I am told are the worst tires for tight fits.
How much lower is your car from stock... I lowered my car 2", and, if changing my pads will prevent rubbing as in your case, maybe I'll live with having the car a little higher...
Ben, how much work are we talking about? Is it just better to run 235/35 & 265/30 based on the cost of the body work???
TNH, so were you running 245/40 Front & 275/35 Rear???
Good luck
TNH are you running 19" or 18" with those size because I do not see how 275/35/19 can fit on a lowered CLK with little rubbing. 275/35/18 yes but definately not 275/35/19.
